Activity › Forums › Adobe After Effects › Slow refresh rate when scrolling timeline
Posted by Sam Freeman on October 1, 2012 at 9:12 amHi guys,
I was just wondering whether other people were experiencing a slow refresh rate when trying to scroll the AE timeline in CS6. It was slightly irritating when I was using a mouse, but useable with some practice, but I’ve just bought a tablet and I’m struggling a bit.
So, when I have a set of laters that are too big to fit in the screen I whip up and down the layers to get to those I want – often from layers keyframes to the camera keyframes and back. I find with the tablet pen I try and scroll and the timeline chugs down really slowly, maybe 3 or 4 seconds after I release the pan/scroll button…
Anyone know why this is happening?
SamFélix Henry replied 7 years, 5 months ago 12 Members · 14 Replies -
Chris Warren
October 1, 2012 at 5:48 pmDecrease the resolution in the Preview to half, or lower if needed
“You are the universe experiencing itself”
ChrisW
http://www.azprovideo.com -
Sam Freeman
October 1, 2012 at 7:45 pmSorry Dave, should have been more specific. Apologies!
I’m doing a comic book layout with frames made in illustrator, (cont rasterise on) and then HD ProRes footage in the different frames. These are masked out using track mattes (solids). Then I animate around using a camera. There are lights but I turn them off until I render – same with motion blur etc. It’s nothing taxing really. Classic Renderer. I should note I work in quarter quality for the most part, when building (always have), and changing the resolution of the viewing makes no odds anway (as that’s absolutely fine for navigating around).
Also, it’s not the viewer that I can’t navigate around – that’s fine, it’s scrolling up and and down and left and right in the timeline that causes me issues. It just chugs down layer at a time when you try and scroll down. It’s fine when I use the scroll bars however… Just irritating when you’re in a hurry. I never had an issue with this in CS5 or 5.5, and it’s taken a few months of using CS6 (and the new tablet) for me to get annoyed enough to ask if other people experience it.
SamiMac 3.4gHz i7
16gb Ram
CS6 -
Vince Lund
January 6, 2013 at 10:23 amI seem to be having exactly the same issue… It seems when I have lots of layers on the Timeline (enough to fill the screen) scrolling up and down becomes slow and painful… I’m using trackpad to scroll. Grabbing scrolls bars seems a bit better, but there is still some lag as the scroll is initiated.
**this is scrolling the timeline window up and down, not panning on the viewer**
Anyone having the same trouble? Did you find a solution, Sam? I have multiprocessing off, and 16GB ram.
Cheers,
Vince.
Sam Freeman
January 11, 2013 at 12:53 pmI never actually found a solution for this – I’ve put it down to another small glitch in CS6 which I have to put up with. The benefits of CS6 do generally outweigh the downsides, but I find this so very frustrating. Nothing I do seems to make a difference…
Let me know if you find anything!
Sam -
Johan Weidlerino
March 5, 2013 at 9:16 amI’m having the same issues and while it seems a frequently appearing issue, no fix is done yet. Kind of frustrating.
Even more, as it does not even work to turn the render-engine completely off with pushing capslock. -
Shane Robinson
April 4, 2013 at 7:57 pmseems as though turning off the “After Effects Multiprocessing” dramatically improved it for me. Scroll rate is now as fast as the wheel will go rather than the chunky slow lag that it had before.
Preferences > Memory & Multiprocessing
uncheck “Render Multiple Frames Simultaneously” -
Normann Petkau
June 22, 2013 at 11:27 amHi guys,
after struggling with the same problem for a few months now on my mac (not on PC), I think I have found something that makes scrolling up and down the timeline window so stuttery: It’s the Cache Indicator, the thin line between the work area bar and the layers.
My Solution:
Open the drop down menu of the timeline panel and turn off the option “Show Cache Indicators”… that’s it.
I also noticed, that when it is turned on and there is a caching-process going on the scrolling is stuttery, but when the process is finished (i. e. the line goes from lighter gray to dark gray) the scrolling is smooth.I hope this helps You, it worked for me. But also I have to say, that it is the Mac Version of After Effects I am talking about – on PC I never had this Problem… strange.
Normann
Greg Platt
June 28, 2013 at 1:56 amYou are a LIFESAVER. Turning off the Cache Indicators cleared it right up for me. I hated this issue. Thanks!
Sam Freeman
June 28, 2013 at 8:44 amNormann you are a genius! I’m pretty sure that’s sorted it for me as well. It’s been bugging me for so long but I’ve never got close to sorting it (I’d actually forgotten that drop down menu existed…)
Thanks a million for sorting at and for sharing.
Chouki Merou
February 19, 2014 at 1:20 pmThank you! This issue made me continue working on CS5.5 until now !
However, turning off the Cache indicator make disappear of course the display of the green/blue bar of the RAM/Disk preview. Viewing it can be useful. Any suggestions?
Thanks again
