Activity Forums Storage & Archiving Slow random I/O performance in Windows 2008 R2 with Qlogic 2560
  • Slow random I/O performance in Windows 2008 R2 with Qlogic 2560
    Posted by Xavryn Singhi on May 2, 2012 at 7:02 pm
    We have a server with 2x Qlogic QLE 2560 8-Gb fibre NIC’s connected to a IBM DS8700 SAN and are having some performance issues in Windows 2008 R2, specifically with random I/O
    These servers were running Windows 2003 SP2 and getting good random i/o performance. We measured this with IOMeter & CrystalDiskMark
    This server was migrated to windows 2008 r2 (clean install) and the random i/o performance and latency dropped by 60%-80%. The performance of our application is impacted due to this.
    We have installed the latest firmware and windows drivers and checked this several times.
    Any ideas on how to troubleshoot this issue?
    Jonathan Eason replied 14 years, 4 months ago 3 Members · 2 Replies
  • Steve Modica
    May 3, 2012 at 1:08 pm
    Running gross tests like disk benchmarks only tells you a little about the problem.
    Ideally, you’d have something that let you look at individual IOs so you could see their latency and size.
    For example, perhaps in the new OS, you aren’t getting the same IO size as before. That might be a simple tuning issue. Perhaps you are running out of a disk IO resource after a short period (you would see the IOs stay fast and large, but perhaps stop coming as rapidly since they are queuing up for buffers to allocate).
    On Mac OS X, there’s dtrace, so you can gather a lot of information like this. I’m not a windows guy.
    Steve
    Steve Modica
    CTO, Small Tree Communications
  • Jonathan Eason
    May 18, 2012 at 9:28 pm
    Sounds like you will need to re-tune the system. I would start with narrowing down the i/o paths to single routes and perform a baseline benchmark with ONE tool. Windows Server has built-in Performance Monitoring or there is Process Monitor that you can download via the Windows Sysinternals website. I prefer Process Monitor becuase it is easier to use. If you have both environments running it should be relatively easy to isolate areas of latency within your applications.
