Activity Forums VEGAS Pro Slow preview window… Vegas Pro10
  • Slow preview window… Vegas Pro10
    Posted by David Higgs on February 17, 2013 at 7:25 am
    Hello…
    I am trying to edit a new project using vegas pro10 and the previewing window is far too slow. I have cleaned up my computer, sped it up as much as possible, set the preview window to draft-quarter and it still jumps to the point i cant edit…
    Now i dont have a duel core processor, But my CPU (1.66ghz)handled my last project ok… Now its seems to always be at 100% when previewing anything…
    The only difference i can think of is my video files are now MOV. shot from a DSLR camera vs the AVI’s i used before…
    Is it worth converting all the videos to AVI/WMV or do i just purchase a newer computer?
    Mike Kujbida replied 13 years, 7 months ago 5 Members · 4 Replies
  • Nick White
    February 17, 2013 at 8:40 am
    Try setting the Project properties to a lower resolution.. Lower resolution allows better preview, although obviously if you preview in a full screen, there will be a compromise point.
    _AS FAR AS I KNOW_, from trial and error and reading, the Project Properties do not affect the actual render…._IF_ you don’t just let Vegas do its own thing, and instead use your own resolutions and quality settings when rendering. I _think_ some of the automatic render setups will use the Project Properties as a basis. I have never used them to know. I have read intimations that the Project properties _do_ affect the output, but I have never seen it, and nobody has actually told exactly how.
    Now _there_ is an invitation….:D
    Nick
    Head: Hertz Music
  • Steve Rhoden
    February 17, 2013 at 11:48 am
    Sounds like something else is running/processing in the background,
    double check first to see which other application is open.
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    https://www.facebook.com/FilmexCreativeMedia
    1-876-832-4956
  • Roger Bansemer
    February 17, 2013 at 12:37 pm
    Be sure your preview window is set to “preview (auto)” and not something higher like “good (half).
    Roger Bansemer – PaintingAndTravel.com
  • Mike Kujbida
    February 17, 2013 at 12:43 pm
    [David Higgs] “Is it worth converting all the videos to AVI/WMV or do i just purchase a newer computer?”
    Realistically, with a 1.66 GHz computer, buying a new one is the bet thing to do. Even a basic i7 from a big box store will amaze you with it’s speed.
