Activity Forums Apple Final Cut Pro Legacy Slow playback/editing FCP V.5 0.1 on G4 Powerbook
  • Slow playback/editing FCP V.5 0.1 on G4 Powerbook
    Posted by Steve Green on January 6, 2010 at 5:30 pm
    Hello,
    I recently purchased a used Powerbook G4 1.67 ghz Mac 2gb memory and installed FCP V.5.
    I’m trying to cut my showreel but the vob files that i’ve copied to my hard drive are stuttering on playback, sometimes not even playing at all. Everytime i lay down something into a sequence i have to render, which can take 15 miinnutes for a 20 sec clip. Or it just crashes
    I’m really suprised but it seems it can’t handle these files, and other qt or avi files are much the same.
    I haven’t installed the other applications that come with FCP as i can’t afford the HD space so i’m just running FCP. Currently have 65GB out of 110gb hard drive. Is this an issue? Tried ussing a firewire drive, this is worse.
    Guys, are I doing something wrong? Do i need an older version of FCP, or is my computer just not powerful enough to cut on?
    I am desperate! Please help
    Arnie Schlissel replied 16 years, 8 months ago 3 Members · 4 Replies
  • Arnie Schlissel
    January 6, 2010 at 6:51 pm
    [Steve Green] “Guys, are I doing something wrong?”
    The short answer is that you’re doing everything wrong.
    You’re trying to cut VOB files, you should convert them into quicktime files that will be easier to edit.
    You’re working off of your system drive, which is also busy trying to run your computer.
    You’re working on an older, slower Mac with barely enough memory.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Steve Green
    January 6, 2010 at 8:52 pm
    Thanks for the response. Very to the point.
    I have a 1tb USB2 external drive i’ll try for the media.
    Will an extra 2 gb memory make a noticable improvement in your opinion?
    And when i convert the vob files should i cut them up into smaller chunks to theres less for FCP to handle when importing?
    Any advice is welcome
    P.S Sorry to regular users but after i posted my question i read the admin notes about people posting basic questions on this forum and not using the FCP Basic forum. So as my question was quite basic i posted it there as well. Sorry for any annoyance, apologies to all.
  • Zane Barker
    January 6, 2010 at 10:09 pm
    USB is not recomended for video work. USB uses bursts of data and video needs a constant data rate.
    There are no “technical solutions” to your “artistic problems”.
    Don’t let technology get in the way of your creativity!
  • Arnie Schlissel
    January 6, 2010 at 10:27 pm
    If you can put more memory in your Mac, you should. It will help to stabilize FCP, even though it won’t render faster. Use a firewire drive, not USB. Also, convert your VOB files to something that’s friendlier, like DV.
    Arnie
