Activity › Forums › DaVinci Resolve › Slow playback with GTX 980 GPU/GUI
Andrew Migliori replied 11 years, 5 months ago 4 Members · 32 Replies
Eric Johnson
March 27, 2015 at 7:10 pm[Andrew Migliori] “I also used atMonitor to check my hardware usage and while playing back in Davinci, it was using 15% GPU and 75%+ CPU. Something is indeed wrong!”
Do you have the “Use GPU for RED Debayer” checked in the Resolve settings (cmd-,) under Video I/O, not Project settings? That looks to me like your CPU is doing the debayer and not the GPU…
eric b johnson
online editor | colorist | workflow
https://vimeo.com/ebjohnson/colorreelSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Andrew Migliori
March 27, 2015 at 7:38 pm[Eric Johnson] “Do you have the “Use GPU for RED Debayer” checked in the Resolve settings”
Interestingly, when that is unchecked, the CPU maxes out and GPU goes to about 15%, but when it is checked, the CPU hovers between 60-75% yet the GPU stays around 15%, and there isn’t much of a playback difference between the two options.
Andrew Migliori
Partner, AnderImage
anderimage.com—
Mac Pro 2012 5,1
3.33 GHz 6-Core Intel Xeon
32 GB 1333 MHz DDR2 ECC
GeForce GTX 980 4 GB
OS 10.10.2 -
Paul Provost
March 27, 2015 at 7:40 pmSounds like cuda isn’t installed. Check cuda z. Also you kept your 5770 I hope? You will still need it occasionally for installs etc
http://www.filmandtvcolor.com | colorist | Los Angeles, CA
Twitter: @4kfinish
Andrew Migliori
March 27, 2015 at 7:51 pmHere’s what cuda-z has to say:
It does seem to say that my Nvidia driver is different from the one that is installed (10.2.1 vs my 10.3.1). I’ll start with reinstalling the drivers and see what happens!
Andrew Migliori
Partner, AnderImage
anderimage.com—
Mac Pro 2012 5,1
OS 10.10.2 -
Paul Provost
March 27, 2015 at 7:52 pmWhat does performance page say. Post a grab.
And go back to the f02 driverhttp://www.filmandtvcolor.com | colorist | Los Angeles, CA
Twitter: @4kfinish
Andrew Migliori
March 27, 2015 at 8:00 pm -
Andrew Migliori
March 27, 2015 at 8:16 pmI also can’t seem to go back to the f02 driver. It says “Mac OS X version 10.10.2 (14C1514) is not supported with this package.” even though f02 is also for 10.10.2!
Andrew Migliori
Partner, AnderImage
anderimage.com—
Mac Pro 2012 5,1
OS 10.10.2 -
Paul Provost
March 27, 2015 at 8:52 pmAlso try using the CUDA / Nvidia un installer.
I don’t know man everything seems fine. I would uninstall and re install everything.
I had the 980 yosemite resolve light on a 5,1 3.3ghz 12 core and it was playing red 4k full premium real time.
You should get half good no problem.http://www.filmandtvcolor.com | colorist | Los Angeles, CA
Twitter: @4kfinish
Andrew Migliori
March 27, 2015 at 8:54 pmThanks a lot, Paul 🙂 I’ll keep you posted if I strike gold.
Andrew Migliori
Partner, AnderImage
anderimage.com—
Mac Pro 2012 5,1
OS 10.10.2 -
Paul Provost
March 27, 2015 at 9:04 pmAnd just to be clear there’s nothing stupid going on here like wrong slot, only one aux power cable nothing like that? Also re seat card for the hell of it
Twitter: @4kfinish
