Activity › Forums › Apple Final Cut Pro Legacy › slow playback
  • Posted by Sophie Carapet on October 11, 2008 at 5:00 pm
    Good evening cows,
    I’m having a problem with some footage i got using a screen capture app.
    I captured at a rate of 30 fps. Ive put it into fcp and rendered but playback is really slow.
    is there anyway to change the settings -For this clip only-, so i can paste it into another film that runs at a normal capturespeed?
    my copy of final cut is set to dv pal usually.
    Thanks for all our help…
    Sophie.
    Sophie Carapet replied 17 years, 11 months ago 3 Members · 3 Replies
  • Kevin Monahan
    October 11, 2008 at 5:28 pm
    What is the exact frame rate and frame size of the file?
    What is the exact frame rate and frame size of the Sequence Settings?
    Kevin Monahan
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
  • David Roth weiss
    October 11, 2008 at 5:45 pm
    Sophie,
    If you’re in NTSC land video runs at 29.97, not 30fps. You should probably use that screen capture program again…
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Sophie Carapet
    October 11, 2008 at 8:54 pm
    Thanks for your answers…. I am currently trying to capture using a different frame rate….
    thanks again
