Activity Forums Adobe After Effects Slow play back after rendering – help please
  • Slow play back after rendering – help please
    Posted by Nic Hawkins on March 1, 2010 at 9:08 pm
    Hey, i have a problem where once i have rendered and i go to play back my movie to where i have saved it, it goes extreamly slow, freezes and jumps (while rendering its fine). However when i export the movie and do it that way, the play back is fine.
    Any ideas would be great, thanks.
    Nic Hawkins replied 16 years, 6 months ago 2 Members · 4 Replies
  • Alperen T. ayhan
    March 1, 2010 at 10:01 pm
    It looks like a codec or configuration problem. If you tell me about your computer configuration and players-codecpacks on your OS I may help you to fix this..
  • Nic Hawkins
    March 1, 2010 at 10:10 pm
    I got windows 7 64 bit,
    5 gb of ram,
    2.4 GHz Processor,
    ATI Radeon HD 2600 XT.
    As for players – codecpacks i dont know what that means.
  • Alperen T. ayhan
    March 1, 2010 at 10:37 pm
    configuration is good! ( and perhaps you should turn 5 gigs to 4 or 6 gigs. Because Rams like to work as twins. 1 to 1 or 2 to 2) and the second means like BS-player, mediaplayer classic, K-Lite codecpack etc. whatever if you use one of them just remove all and restart your machine (even the softwares don’t warn, just restart) and install them by this sort: 1st – K-lite codecpack by default settings(I think the last version 5.7.0) 2nd Bs-player (free or pro, it doesn’t matter) Anyway if you don’t use them just get them from the internet by google search, then install like I have told above.
    Always cinema…
  • Nic Hawkins
    March 1, 2010 at 11:28 pm
    Ah right, in that case i dont have any codecpacks, ill try what you said now thanks 🙂 And yeah, im saving for another 2gb ram chip so then i can get 6gb to make the pair. Thank you again.
