Activity › Forums › Apple Final Cut Pro Legacy › Slow Music to Stop
Slow Music to Stop
Posted by Tsunamibob on February 2, 2007 at 9:18 pmI am trying to slow the audio in my track down to a stop. Kind of like a fade out, except I am gradually slowing the speed of the audio.
Tsunamibob replied 19 years, 7 months ago 4 Members · 5 Replies -
Bouncing Account needs new email address
February 2, 2007 at 9:37 pmCan you please be more specific?
Slowing MUSIC… in pitch and tempo?
What have you tried so far?
This is not actually a function of most video editors.
It is a complex audio effect that will cause severe audio artifacts as you change how the music is resampled.
Paul Dickin
February 2, 2007 at 9:58 pmHi
If you use GarageBand music loops, or the supplied sound effect loops that come with Soundtrack Pro, you can simulate this with GB/STP by exporting an end audio sequence several times at slower and slower tempo settings then editing these together in short bits, with a good helping of reverb for the final grind to a halt.Have fun! 🙂
Bret Williams
February 3, 2007 at 6:21 amYou can do this in FCP by slicing the clip up and making each chunk a different speed. The speed and pitch will change. I don’t hear any artifacts. Once the clips are all sliced up you should be able to do roll edits to tweak the amount of time between each pitch change. Obviously the more the better. Most likely if you do it in 5 or 10% increments and do it on a drum beat it’ll sound smoother.
Execution of the whole process is about 45 seconds. Slice, speed change, next. Works great.
Tsunamibob
February 4, 2007 at 2:49 amThanks! Reason #29 as to why I want to acquire and learn After Effects.
