Activity Forums Adobe After Effects slow motion with matched sound
  • slow motion with matched sound
    Posted by Hassan Ibrahim on February 13, 2012 at 11:38 am
    hi. im making a short movie with adobe after effects cs 5. i can use the slow motion with twix plug in but dont know how to match the sound with it as sound plays at original clips speed. need help about this. thanks
    Kevin Reiner replied 14 years, 6 months ago 3 Members · 2 Replies
  • Tudor “ted” jelescu
    February 13, 2012 at 1:56 pm
    If you use Time Remap the audio will be slowed down as well.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Kevin Reiner
    February 13, 2012 at 2:42 pm
    I’m not familiar with the twixtor plug, but if it doesn’t affect the audio, then use time remapping instead.
    Duplicate the layer, turn of the video eyeball and delete the twix plug. If its a constant change in speed, then just go up to layer/time/time stretch. Change the time to match what you did with twixtor to the video. If its not constant change, then enable time remapping and try to match what you did in twixtor.
    Side note: Having never used Twixtor, I am not sure whether it changes the audio. Maybe give AE’s timeremapping a chance with both video and audio. I have found great results with pixel motion turned on. That way you know that you are in sync (not the boy band).
    Good luck,
    Reiner
    Mac Pro 2 x 3 GHz 6-Core Intel Xeon
    32GB Memory
    Dual-channel 4Gb Fibre Channel PCI Express card
    Dell Display (23″ flat panel)
    ATI Radeon HD 5770
    AJA Kona LSi SD/HD capture card
    Rourke 16 TB
    Flanders 2460
    SOFTWARE
    Mac OS X 10.6.5
    FCP 7
    After Effects CS5
    Boris Continuum
    Sapphire Plug Ins
    All Trapcode Plugs
    Zaxwerks Invig
