Slow Motion Question
Posted by Story Catcher on July 7, 2005 at 7:25 pmHello Vegas Folks.
I have a question that is probably only 1/2 vegas question and 1/2 camera question.
I am wanting to film a piece of equipment that spins at 1700 RPM and slow it down so that the spinning can be seen.
I’ve done some tests with the velocity envelopes but I’m still a little unsure – anyone have any advice on the best way to do this?Thanks in advance for your help.
Cheers
HeidiTerje A. bergesen replied 21 years, 2 months ago 5 Members · 6 Replies -
Edward Troxel
July 7, 2005 at 8:14 pmThe velocity envelope can definitely slow it down (in fact, set to 0% it can stop it and negative %’s will go in reverse). Now, are you wanting to actually see something in particular? Or just that there is still motion? For example, if it’s a record you probably won’t be able to get it to the point where you could read the label.
Story Catcher
July 7, 2005 at 8:31 pmThanks Ed
It is a piece of equipment that they want filmed, then slowed down in a video file so that they can see what’s going on while it is spinning.
Speaking of velocity envelopes – is there a way other than dragging the bar up and down to set it to a certain % point? I notice as I drag the bar it jumps a bit and sometimes a setting in between would work better.
Heidi -
Gary Kleiner
July 7, 2005 at 8:42 pmRight click on the node (little box) that, by default, is on the left extreme of the green line and enter any number you like.
As for how to shoot it…
I assume you are not FILMING this, but video taping.
If it were film, we would be talking about how fast the film moves through the camera.With video, you will have to experiment with shutter speed. A very high shutter speed (e.g. 10,000th), will give you much clearer individual frames, but there will be more time elapsed between them.
A slower shutter speed will have less change in position between each frame but will have more motion blur. -
Story Catcher
July 8, 2005 at 6:03 pmthank you Gary – yes, it is video. 🙂
Thanks for the advice and tip on altering the velocity %Cheers
Heidi -
Terje A. bergesen
July 11, 2005 at 10:24 pm1700 RPM
Herein lies a small (possibly significant) problem. 1700 RPMs divivided by 60 seconds in a minute gives you about 28 rounds pr second. If your camera is an NTSC camera, it will snap almost exactly one frame pr round. In other words, slow it down and it won’t be particularly insightful (if they are looking for something in particular). Just blurry.
I don’t know that much about cameras, but would be surprised if you didn’t need a specialty camera for this.
Feel free to correct me, I’m eager to learn.
