Activity Forums Apple Final Cut Pro Legacy Slow Motion Problem on DVD
  • Slow Motion Problem on DVD
    Posted by George Marsh on August 26, 2009 at 10:58 am
    Ran Slow motion shot through Optical Flow. Imported onto time line in FCP and it looks SWEET.
    Its slowed down to 10%
    Problem is when I use compressor and best quality 90 min to make a DVD the slow mo is Horrible. It is a pause, frame, pause, frame look. Almost like all the frames Motion came up with are missing.
    What should I do.
    Please help. Need the shot.
    Thanks.
    Ralph Atkinson replied 17 years ago 3 Members · 4 Replies
  • David Roth weiss
    August 26, 2009 at 4:00 pm
    First, how are you monitoring FCP, on a computer display, or a true video monitor?
    Next, how are you viewing the DVD, on your computer or on a monitor via a set top player?
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
  • George Marsh
    August 26, 2009 at 6:09 pm
    Viewing on a mac cinema display. While in FCP
    DVD after compressor looks horrible on the Preview that pops up, and when played on any tv dvd combo or any laptop.
  • David Roth weiss
    August 26, 2009 at 6:16 pm
    George,
    One would have to infer that you might have a field order issue that your are unable to see in FCP on a computer monitor. This is precisely why viewing on a broadcast monitor or even a TV via a I/O card/device is so important.
    So, you’d best start at the beginning and tell us what format you’re cutting and what your sequence settings are, etc.
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Ralph Atkinson
    August 27, 2009 at 4:05 am
    Hi George,
    How did you bring your Motion slo-mo into FCP?
    I’m by no means an expert at this, but one thing I have noticed is that I sometimes get a similar effect if I’ve done an effect in Motion then just dropped the file on the timeline. Looks great until I burn a DVD, I have no idea why.
    But, I’ve found that if I export the finished product out of Motion as either the format that is your sequence settings (ie DV, DVCPROHD, etc) or even as the standard animation codec (if you need the alpha channel), then drop the resulting file into FCP I get the results I’m looking for.
    Maybe this is your issue.
    Ralph
