Activity › Forums › Adobe After Effects › Slow Motion Plug In
Slow Motion Plug In
Posted by Aaron Cadieux on March 30, 2007 at 2:40 amI am looking for a good slow motion plug in for either Premier Pro and/or After Effects. Any suggestions?
-Aaron
Shin Kurokawa replied 19 years, 5 months ago 6 Members · 5 Replies -
Danny Princz
March 30, 2007 at 3:47 amif you have AE7, then it comes with one (might be pro version only)
if not there is realviz retimer, re:vision twixtor.
the foundry has kronos in its furnace for AE package which i think is what adobe incorporated in to ae7
who is that masked man…
Brian Kayfitz
March 30, 2007 at 5:36 amIf you don’t already have Timewarp (It comes with AE7pro) then you can play with Time Remapping + Frame Blending
Brian Kayfitz
High Definition Authoring
http://www.infinitehd.com -
Majorasshole
March 30, 2007 at 6:51 amYou can also shoot 60p and then play that in a 24p or 30i or 30p timeline. That is the proper way. DVX100, HVX200 or Varicam.
Shin Kurokawa
April 1, 2007 at 1:33 amI’d suggest that you check out all the different
options that are out there, as each one is better
at certtain things than another solution.If you want a very, very tweakable solution,
RE:VisionFX Twixtor Pro is up there —
here, not only can the user override the motion
estimation, a separate footage can be fed
(ex. contrast-exaggerated) , in case
of bad tracking. YMMV. Again, another solution
might be better at certain types of footage.As with any effects of this type, the more
temporal (and spatial) samples and less inter-frame
differences the better the end result. Also, optic-flow
algorithms are extremely sensitive to brightness
changes over time, so it’s recommended
to de-flicker as much as possible prior to using
these.Of course, if the more-traditional ‘dissolve-y’,
blurry type of slo-mo is what you’re after (…as opposed
to ‘new’ inbetween frames being created from warping/
morphing frames etc), there’s no need for optic-flow-based
solutions.-Shin
