Activity › Forums › Apple Final Cut Pro Legacy › slow motion on HDV
  • slow motion on HDV
    Posted by Antonio Atzei on May 6, 2007 at 2:45 am
    I`m just about about done editing a short film for an up coming festival here in Sydney.
    I`m not really happy with the quality of a slow motion sequence.
    The footage has been shot on a SONY Z1.
    I`m familiar with GOP structure of the Z1 , is this an issue in obtaining a perfect slow motion.
    I`m eding in HDV then transfering the all sequence on a DV sequense for final DVD output.
    Txs
    BABALOTTI PRODUCTIONS
    SYDNEY
    Antonio Atzei replied 19 years, 4 months ago 3 Members · 4 Replies
  • Andy Mees
    May 6, 2007 at 8:15 am
    FCP’s slowmo ain’t all that regardless of the source format, tho surely HDV won’t help.
    you might want to try using the compressor method for a higher quality slomo
    https://proapptips.com/tips/article.php?story=20050706012856432
    or look at ReVision Effect’s Twixtor or RelaViz’s ReTimer
  • Antonio Atzei
    May 6, 2007 at 1:09 pm
    TXS Andy!
    SYDNEY
  • Bbalser
    May 6, 2007 at 1:53 pm
    Shake, Motion, and After Effects will all give you better slo-mo than FCP. Also, if you had used the AIC instead of native HDV the slo-mo would have come out better. I’ve found tons of reasons to never edit HDV natively always using AIC, and not one reason to edit native HDV.
    – Apple Certified Trainer
    – Tutorials at http://www.bbalser.com
    – South Louisiana FCP Users Group
    – NOVAC Digital Filmmakers Institute
    – Event DV magazine
  • Antonio Atzei
    May 10, 2007 at 2:08 pm
    Txs bbalser I`ll give it a go!
    Why I edit in HDV you ask… well it look ok no artifacts or bands etc etc. not at list at this stage anyway, But I`m eager to try your suggestion.
    Regards
    SYDNEY
