Activity › Forums › Apple Final Cut Pro Legacy › Slow motion judder
  • Slow motion judder
    Posted by Phil Beastall on July 7, 2008 at 9:26 am
    I have some HDV 1080i50 footage that when I slow down, it goes really juddery. When stepping through the frames, it will play 2 frames in the right order, and then will skip backwards a frame, so its not actually running in forward motion but jumping to and fro. I have taken off frame blending which has helped but now looks juddery, so I had to add motion blur. Is there anyway to get around this?
    Jerry Hofmann replied 18 years, 2 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    July 7, 2008 at 1:53 pm
    Try using Motion for the slow motion instead. It uses optical flow technology, and is much better than what FCP does.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
