Activity › Forums › Apple Final Cut Pro › Slow Motion From Stills
  • Steve Connor
    July 6, 2018 at 5:47 pm
    Have you tried changing the duration on a video clip rather than the stills using the same technique?
  • Michael Lescord
    July 6, 2018 at 5:55 pm
    Yes, it doesn’t work there either. Thanks for this question, still on hold…
  • Jeremy Garchow
    July 6, 2018 at 5:57 pm
    Do you have a custom keyboard shortcut setting selected?
    Try toggling to the default.
  • Michael Lescord
    July 6, 2018 at 6:14 pm
    I suddenly like FCPX again, but geez is it touchy.
    The problem was quite simple. After selecting all the photos in the timeline, I clicked in the viewer window, which is incorrect. All that is needed is to hit ctrl D and type the number 1 and hit enter.
    Problem solved!
    Thanks to all for timely responses and help.
  • Steve Connor
    July 6, 2018 at 6:49 pm
    [Michael Lescord] “I suddenly like FCPX again, but geez is it touchy.”
    I don’t think it’s FCPX’s fault that it didn’t correct your mistake for you!
  • Mark Smith
    July 6, 2018 at 9:45 pm
    YOu should have clear sailing now.
    Depending on hardware, X can handle varying amounts of stills. If you have some maxxed out you’ll handle a larger mass of stills than if you have a Mac mini. Sometimes I need to do work on a 2012 iMac which will cope with around 1000 stills in a project before its gets sticky . This is what drove me to make pro res stills sequences in compressor and then move those sequences into X. Typically I might be working with stills sequences that involve several thousand stills if not more .
    You should have ‘clear sailing’ now that you are over this hurdle .
  • Michael Lescord
    July 7, 2018 at 12:27 am
    Luckily I knew this was only a glitch and continued amassing my libraries at sunset into the night. I’m processing these files now and seeing things described online but something I can reproduce and physically verify.
    Clear sailing indeed, only with the horizon in sight!
  • Eric Santiago
    July 9, 2018 at 7:22 pm
    [Michael Lescord] “I just googled “FCPX sucks” and came up with an incredible list.
    There are some things that require the right tool and for me timelapse always ends up in After Effects.
    You are a brave man for attempting this in FCPX which is my go-to NLE 🙂
Page 4 of 4
