Activity › Forums › Apple Final Cut Pro › Slow Motion From Stills
  • Jeremy Garchow
    July 6, 2018 at 3:17 pm
    [Michael Lescord] “Hmm, wonder why you can’t search FCPX for delete preferences and get an answer? Maybe the program is not very good?”
    Here’s a search for delete preferences in Adobe Premiere. It also turns up nothing:
    I am sorry you are having trouble with this, Michael, but this process works in FCPX. I use this exact process a lot, and does what you are trying to do. There is obviously something wrong, we just have to find out what it is.
  • Michael Lescord
    July 6, 2018 at 3:23 pm
    I see the duration was changed and all of the photos on the timeline changed width to a smaller size to reflect that. I am not getting this. Also, I see you change the 4 sec interval in the viewer to 1 sec, which I do but I didn’t see that you selected all of the photos in the timeline before doing that.
    Again thanks for the help, and I apologize for the frustration but it really shouldn’t be this hard. This is pretty basic stuff after all. Maybe I should go back to iMovie or just give up and accept the loss.
  • Mark Smith
    July 6, 2018 at 3:45 pm
    Are you using X version 10.4.3?
    When you selected all the clips in the index – rolled the mouse over to the the time line and saw all the clip marquees turn yellow then CTRL D type in duration and nothing happened?
    If you make the compound clip without changing the durtion of stills to 1 frame, then yeah, the result won’t be what you want.
    I’m a little mystified why control D doesn’t allow you to change duration of those still frames. It works ths way on all my machines.
  • Jeremy Garchow
    [Michael Lescord] “Also, I see you change the 4 sec interval in the viewer to 1 sec, which I do but I didn’t see that you selected all of the photos in the timeline before doing that.”
    At about :13 you can see me select all (I hit command-a) and all the clips turn yellow, meaning they are selected.
  • Jeremy Garchow
    July 6, 2018 at 3:55 pm
    [Mark Smith] “When you selected all the clips in the index -“
    I added some notes on the vimeo review page so you can follow along. I don’t select clips in the index, I just selected all on the timeline (command-a).
    [Mark Smith] “rolled the mouse over to the the time line and saw all the clip marquees turn yellow then CTRL D type in duration and nothing happened?”
    Control-d turns the tc window to blue. When it’s blue, you can add a custom duration, to which I typed “1.enter”
    [Mark Smith] “I’m a little mystified why control D doesn’t allow you to change duration of those still frames. It works ths way on all my machines.”
    But that’s exactly what I did. I am not sure what you are doing wrong. Open quicktime, select File > New Screen Recording, and record what you are doing. You can post the file here to the Cow if you don’t have a streaming service such as Vimeo/Youtube/other. Click the little “disk” icon above the response text box to upload a file to this website, and copy/paste the link and reply here with that link.
  • Michael Lescord
    July 6, 2018 at 4:20 pm
    Ok thanks, I do the same with Cmd A. It looked like you changed duration of just one photo then it magically was applied to them all. Hopefully I can get this cleared up with Apple support in a half hour or so.
  • Steve Connor
    July 6, 2018 at 4:33 pm
    [Michael Lescord] “Again thanks for the help, and I apologize for the frustration but it really shouldn’t be this hard. This is pretty basic stuff after all. Maybe I should go back to iMovie or just give up and accept the loss.”
    I understand you’re frustrated but this is a system problem NOT a functionality problem, I’ve just tried 600 stills and it works every time.
    Select all clips – Ctrl-D – 1 – return
  • Michael Lescord
    July 6, 2018 at 4:36 pm
    Yup, thanks been doing that over and over and over. Will post results from Apple support.
  • Mark Smith
    July 6, 2018 at 5:25 pm
    At this point I’d have to agree with Steve Connor that the issue is some sort of system problem, ctrl D isn’t mapped properly, maybe you need to trash your installation of X and reinstall. Something. I work with lots of digital timelapse frequently and changing duration of stills is a snap, though as I said earlier, my preferred workflow is run my stills through compressor to create an image sequence and then import the image sequence into X. I do this only because sometimes my stills number in the many thousands and that can be cumbersome in X at some point.
    I’l wait to hear what apple has to say on the subject….
  • Michael Lescord
    July 6, 2018 at 5:44 pm
    So your right, Apple had me uninstall/reinstall FCPX and that didn’t work either. I’m on hold again right now for further advice from Apple.
    This program has quite limited functionality for me at the moment.
Page 3 of 4
