Activity › Forums › Adobe Premiere Pro › Slow motion and time remapping work-flows – AE or Premiere? or both?
  • Slow motion and time remapping work-flows – AE or Premiere? or both?
    Posted by Ori Kuper on February 27, 2012 at 3:22 am
    Hello,
    I’ve looked in other post, and did find some info about HOW to use AE for slow-motion or time remapping. But i think i’m missing something in the work-flow itself. From what i’ve read, AE has more graphic power, and therefore should be used for effects of post, color corrections etc. Also i got the impression that because of this graphic power, AE can handle better the tasks of slow motion and time remapping (pixel motion ability for example). Is that right? I’m trying to figure out what should be my workflow with anything that is involved with slow motion and/or time remapping; premiere ? EA? Interpret or slow-mo or just time warp? Or all the above?
    Part of the reason for me re-considering my work flow – i’m now starting to use some 60 fps (progressive yet still 60 fps) materials from my go-pro camera. They are progressive so other than interpret to 30 and then maybe some more slow-mo or remap or warp – i don’t have too much, but those materials do give me some more ‘slow-mo’ to work with than i had until now. I comfortable editing with premiere, and until now i was always cutting and slow mo-ing or remapping in premiere as well, and only at the end sending the final sequence to AE for colors/titles…
    should it be like that? or should i send / copy specific time manipulating shots to AE and then back to the timeline in premiere? and since stuff can be only linked in one direction – which direction should be linked? i’d like to hear how you deal with that type of stuff / shots. any info would help.
    Thanks! Ori.
    p.s. posting this also in the AE forum.
    Ori Kuper replied 14 years, 6 months ago 2 Members · 2 Replies
  • Todd Kopriva
    February 28, 2012 at 9:20 am
    I’d use The Replace With After Effects Composition command to use Dynamic Link to send short shots from Premiere Pro to After Effects for time-remapping. But what works best depends greatly on details of the shots and your system. The only way to know for sure what works best for you is to try it. You may find that you need to render intermediate files in some cases.
    What, exactly, do you mean by this? I suspect that you may be referring to a limitation that no longer exists. See this:
    “Dynamic Link in CS5: no longer a one-way street”
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Ori Kuper
    February 28, 2012 at 8:27 pm
    hmmm… i didn’t know this limitation was fixed. now it makes more sense to work smoothly between them and use each for specific ‘patches’ when needed. i’ll look more into that workflow. thanks Todd!
