Activity Forums Apple Final Cut Pro Legacy Slow motion and Speed changes in FCP
  • Slow motion and Speed changes in FCP
    Posted by Andrew Gregg on April 8, 2009 at 5:59 am
    I’ve got loads of footage of a BMX competition shot 60 fps in a 720 24p format. I’ve dropped this footage into a 24 fps timeline, so it’s all in 2.5 slow motion.
    What I’m trying to do is affect all of the footage so that it plays at regular speed (2.5 X the original footage), but then at certain spots get it to slow down and speed up for speed ramps.
    What’s the fastest way to go about doing this?
    Thanks for your help.
    Andrew Gregg
    Director
    LiveABC Taiwan
    Trent Whittington replied 17 years, 4 months ago 4 Members · 6 Replies
  • Rafael Amador
    April 8, 2009 at 6:38 am
    [Andrew Gregg] “I’ve got loads of footage of a BMX competition shot 60 fps in a 720 24p format. I’ve dropped this footage into a 24 fps timeline, so it’s all in 2.5 slow motion. “
    No. Your p60 footage will be badly converted to p24 and will play at normal speed.
    You need to open your p60 footage in CinemaTools and conform it to p24. In this process there is no rendering so no quality lost.
    Then when you import to FC will be played 2.4 times slower.
    rafael
    http://www.nagavideo.com
    (and here some clips for the friends: https://www.vimeo.com/2694745 )
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Andrew Gregg
    April 8, 2009 at 7:06 am
    The quality is fine now. I recorded in a 24fps base at 60 fps, so the footage looks fine in the 24fps time line.
    What I need to do is make all of the footage normal speed, and slow it down just at certain points for impact. I’m looking for a fast way to do this.
    Thanks for your suggestion though.
    Andrew Gregg
    Director
    LiveABC Taiwan
  • Tom Wolsky
    April 8, 2009 at 7:13 am
    Sounds like you need Time Remapping. You should look that up in the manual and read about it.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
  • Andrew Gregg
    April 8, 2009 at 7:33 am
    Another thing I’m looking to do is to be able to time warp clips as if they had the start and ending points I cut them down to in the time line.
    I’m running a multiclip and then I cut between the two cameras. After these cuts are done, I want to ramp the speed from one shot to another, so the transition is seamless.
    I need the final frame of where I made the cut, not where the original media ends. It’s much nicer to work with a short clip in the time remap. Working with a long one is difficult because it’s x/y axis is so long that if you make a minor adjustment, you speed up your clip by 5000%, or have it turn in to a still.
    I know I can export the individual clip and work like this for every cut, but surely there’s a better way to do this.
    Any ideas?
    Andrew Gregg
    Director
    LiveABC Taiwan
  • Andrew Gregg
    April 8, 2009 at 7:35 am
    Yeah, unfortunately the manual doesn’t get into the nitty gritty aspects of things! I’m looking for shortcuts. I know I’m lazy.
    Andrew Gregg
    Director
    LiveABC Taiwan
  • Trent Whittington
    April 8, 2009 at 1:45 pm
    “Another thing I’m looking to do is to be able to time warp clips as if they had the start and ending points I cut them down to in the time line.
    I’m running a multiclip and then I cut between the two cameras. After these cuts are done, I want to ramp the speed from one shot to another, so the transition is seamless.”
    Hi Andrew,
    You could do this by making the two cameras have the same time re-map and too simply keyframe one clip in the motion tab then once you are happy, simply copy the attributes from that clip and paste the time re-map attributes onto the other clip(s).
    Hope that helps 🙂
    Trent Whittington – Currently studying Associate Degree in Digital Television
    iMac – 24inch 3.06Ghz, FC STUDIO 2, Adobe Production Premium CS4.
    Asus eee – 8.9inch 1.6Ghz 1Gb Ram, Windows XP
