Slow Motion and Fast Motion?
Posted by Ken Bennett on August 10, 2010 at 1:32 amIt looks like I can change the playback speed for slow motion in Vegas down to about 25%. That’s fine. But I also do “hi-speed” motion clips up to around 1000%. But it appears Vegas can only do about 400%. Is there a way Vegas can do hi-speed clips? (without actually shooting them in hi-speed)
Ken Bennett
Video Adventures
Capturing Your Life’s Adventures!Mike Hinkel replied 16 years, 1 month ago 5 Members · 6 Replies -
Jeff Schroeder
August 10, 2010 at 3:45 amKen,
I like using the script RenderImageSequence and then import the pictures as motion footage. 1 frame per second = 30 times faster ( if original is 30 fps) Try it with a motion blur on the video bus, you can get some cool effects. There are scripts available with more flexibility than the built in render template.
I think you will find this on Ed Troxel’s site. Anyone else know the download location of this?
Jeff
http://www.narrowroadmedia.com
Aleksey Tarasov
August 10, 2010 at 3:48 amIn addition to the playback rate you can add velocity envelope to your clips, so the speed can be increased up to 12X
John Rofrano
August 10, 2010 at 2:42 pmIn addition to the playback rate you can add velocity envelope to your clips, so the speed can be increased up to 12X
…and if that’s not enough, speed the clip up 12x in a separate project (veg file) and then drop that veg file into your main project and speed it up another 12x (which is 12 times 12 or 144x!)
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Mike Hinkel
August 11, 2010 at 3:27 amHow do you drop a .veg file into a veg.file open on he timeline or do you mean a rendered project.
John Rofrano
August 11, 2010 at 4:09 amHow do you drop a .veg file into a veg.file open on he timeline or do you mean a rendered project.
You drop a .veg file onto the timeline just like any other piece of media. No rendering! It’s called a nested project and is the equivalent to comps in After Effects. It’s an extremely powerful concept when entire projects can be treated like any piece of media and trimmed and cropped and stretched, etc.
~jr
Mike Hinkel
August 11, 2010 at 11:04 amThanks John, I have to give that a try. So much to learn and your help is appreciated very much.
