  • Posted by Andrei Bocharnikov on June 15, 2010 at 3:19 pm
    Hi.
    I have a problem with slowing down footage in FCP. For example 75% speed makes irregular double frames every 4 frame and it makes footage looks juddering or steppy.
    I was trying to do it in Compressor setting frame control timing to motion compensation but it makes strange blending or artifacts.
    Motion has optical flow but no settings and it looks morphy.
    MacPro Dual Quad 2.8 GHz, 4 GB DDR2 SDRAM, Leopard 10.5.8, QT 7.6.6, FCS3
    Rafael Amador replied 16 years, 3 months ago 4 Members · 5 Replies
  • Jeremy Garchow
    June 15, 2010 at 4:47 pm
    Motion does have settings. You can set the type of image analyzation.
    Optical Flow tends to be ‘morphy’. Also, I’d suggest trying different types of analyzation in Compressor, not just best (or optical flow). If none of that works, try a plugin like Twixtor which is built just for this and has ways of dealing with morphing.
    https://revisionfx.com/products/twixtor/
    It might help to watch this too:
    https://library.creativecow.net/articles/freitag_lori/twixtor-fcp-overview.php
    Jeremy
  • Andrei Bocharnikov
    June 15, 2010 at 5:25 pm
    Thank you guys for the respond!
    Footage is 25 fps, DVCPRO HD 720p50
    Twitor is quite costly Jeremy 🙂 … i am watching now overview from the link you provided.
  • Jeremy Garchow
    June 15, 2010 at 5:43 pm
    [Andrei Bocharnikov] “Twitor is quite costly Jeremy :)”
    Yes, but if the built in tools aren’t doing it for you….then it might be worth it.
    Jeremy
  • Quintus Lubbe
    June 16, 2010 at 11:39 am
    I have often found that turning off the “Frame Blending” option in the FCP slow motion window solves blurs and smears. Perhaps try that before whacking out the dollars.
  • Rafael Amador
    June 16, 2010 at 12:03 pm
    I agree with Jeremy.
    Twixtor allows total control because you can key-frame all the parameters.
    With Motion or Compressor you can not and sometimes the results are horrible.
    here you can see the differnce:
    https://library.creativecow.net/articles/freitag_lori/twixtor-overview.php
    rafael
    http://www.nagavideo.com
