Activity Forums Apple Final Cut Pro Legacy slow mo problems?
  • slow mo problems?
    Posted by Joseph Farris on August 2, 2005 at 2:15 am
    Hello all
    has anyone else come across this problem or am I simply missing some obvious step… When I mark a clip with an in and out point in the source window and set the slow motion to something other than 100 percent, in this case 90% and drop the clip in the timeline the actual clip that ends up in the timeline is no where near what I had marked as an in and out point. anyone have any ideas? Thanks in advance.
    Joseph Farris
    Director of Photography
    Visions of Light, Inc.
    Office: 312-829-8244
    Pager: 800.808.8244
    Mobile: 630.306.8244
    Fax: 630.690.7678
    http://www.visionsoflightinc.com
    joe@visionsoflightinc.com
    Les Kaye replied 21 years, 1 month ago 3 Members · 2 Replies
  • Shane Ross
    August 2, 2005 at 4:38 am
    Make sure that you only have an IN point chosen in the timeline and not an OUT point. This way it will only put in what you marked in the viewer.
  • Les Kaye
    August 2, 2005 at 5:16 am
    [Shane Ross] “Make sure that you only have an IN point chosen in the timeline and not an OUT point. This way it will only put in what you marked in the viewer.”
    Unfortunately this really doesn’t work if you’re replacing an already existing shot. I find the slomo workflow in FCP a particularly clunky implimentation when compared to most other NLE’s. However Joseph, the workaround is to do a quick calculation of the source in & outs for the motion effect you need, and then do a fit to fill, which is in real time.
