Activity Forums Adobe Premiere Pro Slow-mo frame rate math help!
  • Slow-mo frame rate math help!
    Posted by Kelly Black on July 12, 2024 at 11:20 pm
    Hey all looking for help with anyone better at math than me (clearly I’m horrible.) I have some footage that’s 23.98fps – but it’s playing slow motion. So clearly it was originally shot at 60- 120fps and exported as 23.98. So now I’m editing trying to get it to play realtime and I’m too horrible at math for this. Anyone know how to figure out how much I should speed it up if it was shot at 60fps and the math for 120fps as well please! I know that if I was slowing it down it would be 60fps = 40% 120fps = 20%, but I don’t know why I cannot seem to do this math the other way 😢. Would speeding up the 60fps = 160% and 120fps = 180% ?? Ha I have no idea. Thank you!!!
    Mark Grance replied 2 years, 2 months ago 3 Members · 3 Replies
    July 13, 2024 at 10:01 am
    Hey Kelly,
    Looks like you found the answer.
    Solved by FCP Legacy, many years ago:
    https://creativecow.net/forums/thread/make-slow-mo-with-footage-look-like-regular-speed/
    Please do share if this work-around worked?
    Adding that when fiddling with frame-rates and progressive video, watch out for flicker in the black levels of your video.
    Should not be a problem if converted from 12fps, but if that originally were converted incorrectly, you may experience flicker in the black areas of the image – all depends on a large number of factors. So it might not be there.
    Well done to you for finding the solution!
  • Kelly Black
    July 14, 2024 at 7:52 pm
    Thanks so much! Yes the answer was in the comments of what you shared from that FCP legacy post. It’s this:
    Math. 59.94/23.98=2.49958 (250%)
  • Mark Grance
    July 15, 2024 at 3:36 pm
    Wouldn’t another solution (if you know the capture rate) be to Modify>Interpret footage…
