Activity Forums VEGAS Pro slow-mo effect
  • slow-mo effect
    Posted by Jhbrewer on January 10, 2006 at 10:31 pm
    I am new to Sony Vegas, I’m used to Premiere Pro, and I have several questions.
    First, I’m making a short clip for fun that involves a slow motion effect. However, I didn’t find it as simple as in Premiere (or maybe it was After Effects, I can’t recall). I finally figured out to use either the playback rate or undersample, but the help file mentioned the duration limiting it. Simply put: What is the easiest way to make a section of a clip slow motion?
    Also…. What is an event!?! It seems like everything revolves around events, but I can’t figure out what they are! Could someone explain this or point me in the direction of a good tutorial?
    You think your computer sucks?
    1.1 GHz Intel Celeron
    512 MB PC-133 SDRAM (upgraded from 128)
    17″ Gateway CRT + secondary 15″ ZDS (slow as christmas when I use it, though)
    2 x 20 GB, 1 x 160 GB HDDs (upgraded from 1 x 20 GB)
    Edward Troxel replied 20 years, 8 months ago 3 Members · 4 Replies
  • Gary Kleiner
    January 10, 2006 at 10:51 pm
    [jhbrewer] “What is the easiest way to make a section of a clip slow motion?”
    Ctrl/drag the in or out point. Done 🙂
    Also do a search or check the help file for Velocity envelopes.
    An event is any timeline element: Media file (trimmed or not), generated media, etc.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Gary Kleiner
    January 10, 2006 at 10:53 pm
    As it re-read and see you are referring to a SECTION of an event;
    you either have to split the event (s key)then Ctrl/drag the section you want to change, or you will need to apply a Velcocity envelope.
    Gary Kleiner
  • Jhbrewer
    January 10, 2006 at 11:37 pm
    Thanks! I’ve practiced a bit with these velocity envelopes and although it has a learning curve, I’ve found it to be an extremely powerful feature. I’m doing a highlights video for a friend’s backyard football game (set to Numb by Linkin Park!) and I’ve got slow-mo and I actually accidentally found out how to reverse footage, and it all makes for a great effect.
    Thanks so much!
  • Edward Troxel
    January 11, 2006 at 1:12 am
    I also have a full writeup about changing speeds in Vol 1 #9 of my newsletters. If you haven’t, check them out (link under my name).
    Edward Troxel
    JETDV Scripts
