Activity Forums Apple Final Cut Pro Legacy slow going in HD
  • slow going in HD
    Posted by Sbrand on June 21, 2007 at 2:10 am
    We are working on the newest Intell Macs and I can’t understand why the playback is so slow that audio is out of sync. I rendered one HD clip, and everything worked fine.
    Is there a guide to keeping a system optimal for ND editing?
    Jeremy Garchow replied 19 years, 2 months ago 4 Members · 5 Replies
  • Jeremy Garchow
    June 21, 2007 at 2:48 am
    Need way more info, such as speed of scratch drives, codec, RAM, OS, version of FCP, etc etc etc
  • Bart_s
    June 21, 2007 at 3:43 pm
    6.0 4 gigs of ram OS 10.4.9
    2 x 3 GHz Dual-Core Intel Xeon
    Scratch disc is an internal Hitachi HDS725050KLA260 465 gig capacity.
  • David Bogie
    June 21, 2007 at 4:49 pm
    That’s a good start.
    Which of the dozen or more “HD” formats?
    bogiesan
  • Bart_s
    June 22, 2007 at 2:16 pm
    From movie info:
    Uncompressed 8 bit, 1280 x 720, millions
    24-bit integer (Big Endian), Mono, 4800 KHZ
    FPS: 23L98
    data size 58.72 MB
    Data Rate 377.01 mbits/sec
    If you can tell me how to find more information about the clips, I will be happy to supply it.
  • Jeremy Garchow
    June 22, 2007 at 2:30 pm
    You are trying to do uncompressed HD off of a single SATA drive?
    For uncompressed HD you need a 5 drive array or better.
    Try capturing to the DVCPro HD codec, even then, you should have a two drive striped array at the least.
    Jeremy
