Activity Forums Square Box CatDV Slow framerate playback in Pro trial using Quicktime
  • Slow framerate playback in Pro trial using Quicktime
    Posted by Shane French on January 9, 2014 at 10:50 pm
    Am evaluating CatDV won Win 7. I’;m having an issue with playback of h.264 files. The framerate is slow (guestimate 12-15 fps) within CatDV. Have tried regular and protected mode player within CatDV, same slow result.
    Playing same files in standalone Quicktime Player works fine, video is smooth.
    Now, I have realized that if QT’s audio playback is set to anything other than 16-bit 44.1, the player exhibits the same issues. Who knows why (of course, the same files play fine in all other apps). Does CatDV force playback at a different audio setting? Could explain the issue I suppose.
    Additionally, playback is smooth within CatDV using Directshow, etc…but it causes VERY frequent crashes (can provide error log if anyone wants to look at it).
    This is a fresh install of Win 7 64-bit. nVidia GTX680.
    Hoping I can get one of the two options working satisfactorily!
    Shane
    Charlie Langrall replied 12 years, 3 months ago 3 Members · 3 Replies
  • Bryson Jones
    January 11, 2014 at 1:41 am
    Shane, are the files on a local drive or on a network?
    There are many issues with QT files playing over a network on Win.
    (You might search here for UNC path issues.)
    Hope that helps.
    bryson
    bryson “at” northshoreautomation.com
  • Shane French
    January 11, 2014 at 2:33 am
    Hey Bryson,
    Nope, they’re on a locally attached SAS RAID – blazing fast.
    Shane
  • Charlie Langrall
    June 2, 2014 at 10:24 am
    Was this issue resolved? I’m also seeing slow/hitchy playback of h.264 proxies in CatDV Pro 10.1.1 on Windows 7 (not a trial version). The same proxies play smoothly in QuickTime Player, Windows Media Player and they work as expected in the web client.
    -Charlie Langrall
