Activity Forums Adobe Premiere Pro Slow DSLR on PP CS5.5
  • Slow DSLR on PP CS5.5
    Posted by John Welsh on June 3, 2011 at 8:10 pm
    I have been shooting with D7000 (with latest firmware) for a few months and playback while editing is smooth under PP CS5.
    Under CS 5.5 it’s choppy. It slows down then stutters, then speeds up and then repeats. It only happens with D7000 files on 5.5 AVCHD files from HMC150 work fine on both 5 and 5.5.
    System should be plenty fast (Intel 980x, 12GB, Nvidia 570).
    (Media Encoder has some batch problems as well but that’s for another post).
    Anyone have similar experiences?
    JW
    Jim Wiseman replied 15 years, 1 month ago 7 Members · 16 Replies
  • 16 Replies
  • Jeff Greenberg
    June 4, 2011 at 8:11 pm
    Open up your either the task manager or resource manager in windows – see if the CPU is pegged or not during playback. The resource manager will give you better insight beyond CPU.
    Best,
    Jeff G
    Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
    You should follow me (filmgeek) on twitter. I promise to be nice.
    Come See me speak at NAB!
    Compressor Essentials from Lynda.com
    (older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
    Contact me through my Website
  • John Welsh
    June 4, 2011 at 9:05 pm
    Thanks Jeff,
    I’m getting about 15%- 17% CPU usage tops, though several are “parked.”
    JW
  • Jeff Greenberg
    June 4, 2011 at 10:11 pm
    Any other culprits when it’s playing (drive speed or memory?)
    Best,
    Jeff G
  • John Welsh
    June 5, 2011 at 11:37 pm
    Memory and drive speed also seem Ok. It only happens in 5.5, same files in 5 play fine.
    Lowering playback resolution also doesn’t affect this either. What happens is I’ll start playback, 4-5 seconds go by then it gets choppy. I’ll stop playback, being again, 4-5 seconds later it’s choppy again.
  • Kevin Monahan
    June 6, 2011 at 4:26 pm
    Yes, we know about this problem and are working hard to resolve it. In the mean time, you can transcode the footage and then work in Premiere Pro as described here: https://nikon-videoconverter.com/2011/04/nikon-d7000-video-converter-convertimport-d7000-mov-to-wmvmov-for-adobe-premiere/
    Kevin Monahan
    Sr. Content and Community Lead
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
    Follow Me on Twitter!
  • John Welsh
    June 6, 2011 at 4:51 pm
    Thanks Kevin, I though it may be a bug/upgrade issue since CS5 is pretty solid.
    Also, with 5.5 Media Encoder long queues sometimes don’t finish. No crash, but files have to be subtracted/added and restarted. Where CS5 AME is fine.
    John
  • Kevin Monahan
    June 6, 2011 at 7:36 pm
    John,
    That seems odd. What kind of footage? How long are the queues??
    Kevin Monahan
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
  • John Welsh
    June 6, 2011 at 8:21 pm
    Hi Kevin,
    same footage (Nikon d7000). It’s been behaving lately, but I sometimes batch 50-70 short (duration) files. It’s not easy to reproduce as it’s random.
    While we are discussing AME, I noticed when working with watch foiders the source file is copied to a new subfolder. Having the auto output folder is great but is there way to turn off each source file being moved to its own folder?
    JW
  • Adam Schmidt
    July 17, 2011 at 5:48 am
    I too have had this issue. You only need to change the extension from .mov to .mpg and then use the .mpg files natively with all cpus, in all Adobe applications. The problem is with “Adobe QT 32 Server” only using one CPU, and the network buffer not moving data fast enough.
    You can do this in batch with Bridge.
    Quicktime has no problem reading the changed “.mpg” files natively as well, so there is no reason to keep a copy of the “mov” files.
    Systems tested on:
    MBP i7 quad 2.3 8GB ram SSD. OS10.6.8 and WIN7ult
    MP Octo 2.66 24GB ram Raid. OS10.6.8
    MP Duodecimus (12) core 2.93 96GB ram Raid. OS10.6.8 and WIN7ult
    Adam Schmidt
  • John Welsh
    July 17, 2011 at 6:00 am
    Hey Adam,
    renaming definitely does the trick…and it’s a good fix until they patch this. Thanks lots.
    John
