Activity Forums Apple Final Cut Pro Legacy slow down with Time Remap – I am STUMPED!
  • slow down with Time Remap – I am STUMPED!
    Posted by Mary beth Koplin on October 26, 2008 at 12:02 pm
    I have a 3 second clip, trying to match it to some music. I want to start at 100% speed, then in the middle slow way down to about 20%, then back up to 100%. If it was smooth at the transitions, that would be ideal. I want to keep the same overall duration for the clip.
    I have tried about 5 different methods – been reading, searching, etc. But I don’t seem to have the control I want. The results are all over the place.
    What would you recommend? I am truly stumped…
    David Bogie replied 17 years, 11 months ago 4 Members · 5 Replies
  • Mary beth Koplin
    October 26, 2008 at 4:14 pm
    ok, Arnie, thank you . In my reading I saw that Time Remap requires that the slower part of the clip will require the rest of the clip to be faster, so the duration stays the same. Is this what you are referring to?
  • Arnie Schlissel
    October 26, 2008 at 4:15 pm
    If I understand you, you want the beginning and the end of the clip to be normal speed, while the rest of it is slower than normal.
    At the same time, you want it to be exactly the same length, even though most of the clip is slower than normal.
    Well, as Mr. Spock would tell us, this is not possible without violating the laws of physics.
    In order to do what you want to do, some part of the clip must be faster than normal speed to take up the difference in length.
    If you don’t mind the clip being longer, or your out point being earlier, then what you want is fairly easy.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Arnie Schlissel
    October 26, 2008 at 4:28 pm
    Yup, that’s it exactly.
    Arnie
  • Bob Pierce
    October 27, 2008 at 12:31 pm
    As far as I know, you can’t really do this in FCP – not smoothly anyway. It’s pretty easy in After Effects. Simply enable time remapping for the layer, then create some keyframes at several points within the clip. You can then move the keyframes causing the speed to change. As long as there’s a keyframe at the end of the clip that’s not moved, the run time does not change. Also, applying “easy ease” to the keyframes with smooth out the transitions. Hope this makes sense!
    Bob
    Mac Pro 2.66 – 8GB memory – Mac OS 10.5.2 – Quicktime 7.4.5 –
    Mac Book Pro 2.33 Duo –
    FC Studio 2 (Final Cut 6.0.3) – Kona Lhe
    Adobe Production Suite CS3 –
    Sony Multiformat 14″ – Panasonic 42″ Plasma –
    Ikegami HLDV7 – PVW EX-1
  • David Bogie
    October 27, 2008 at 3:33 pm
    Butting in.
    After years of time remapping in After Effects, I can tell you that it doesn’t matter how many keyframes you use but you must have two keyframes at the end of your clip. Say they’re positioned at the last frame and about 15 frames before the last frame.
    The one at 15 frames tells FCP to make a speed change from this point to the end. The last one tells FCP the clip has ended, no more frames are available. What’s going on is the one 15 frames forces all the rest of the frames that haven’t been used yet to play in the last 15 frames.
    The next-to-the-last KF can be anywhere. It’s only function is to use up all the rest of the frames that haven’t been shown yet. This is best accomplished with about 5 seconds of padding at the ned of the clip so the next-to-last KF can be used to smoothly come to a halt or to smoothly ramp back to normal speed.
    bogiesan
