Activity › Forums › RE:Vision Effects › slow down the footage without jitter
  • slow down the footage without jitter
    Posted by John Suzuki on September 5, 2007 at 9:05 pm
    I have this at work and I’m trying to slow down Cloud stock footage (HD).
    I’m not sure how to use this Twixtor Pro 4.5.
    Could someone point me what I need to do to slow down the speed of footage without jittering?
    thanks
    Pierre Jasmin replied 19 years ago 2 Members · 1 Reply
  • Pierre Jasmin
    September 6, 2007 at 5:32 am
    On our website in the support section of Twixtor there are tutorials and sample projects, that complement the documentation that is installed in the folder where you installed your software.
    Are you using this in AE?
    If so one way is to just drop the footage into a comp, set the comp duration to desired length (in comp settings), then make a new comp from that comp (select comp in project window and File|Mane New Comp…) and apply Twixtor to that (using the speed slider if you are not animating the slowmo)
    Pierre
