Activity Forums Adobe Premiere Pro Slow Clips?
  • Slow Clips?
    Posted by Davidnagel on November 27, 2006 at 3:07 pm
    Hi, didn’t know where to put this since I am having the same problem with Movie Maker… so here goes…
    Capture DV-AVI in Movie Maker.
    Split the entire tape clip into clips via AVCutty.
    Import into Movie Maker or Premiere Pro – the clips audio plays slow when placed and played in the timeline.
    If you play the clips outside of MM or PP the clips play fine (in some places) – clips are used over a Windows 2003 server network. Workstations editing are Windows XP SP2 under restricted user accounts. (The problem is also replicated if the files are not on a network but over a USB storage device and using a non-restrictive user account).
    Can anyone advise anything? The last resort is to recapture the files.
    David.
    http://www.damproductions.org
    Mike Velte replied 19 years, 9 months ago 2 Members · 1 Reply
  • Mike Velte
    November 28, 2006 at 12:10 pm
    I am suprised Premiere even imports the clip captured in Movie Maker as it is DirectShow type 1 file. Suggest recapture with Premiere and dont use the AVcutter thingy as it may be screwing up the file header.
