Activity Forums Storage & Archiving Slow AJA system test
  • Slow AJA system test
    Posted by Glenn Camhi on May 3, 2011 at 4:22 am
    I just ran the AJA System Test on a G-Speed es 8TB RAID5, and the results seem quite slow. Tested 1920×1080 8-bit, 2GB File Size. I got:
    32.5 MB/s write
    121.0 MB/s read
    Just to compare, I tested my internal drives, and got:
    81.0 MB/s write
    55.9 MB/s read
    Those also seem to be slow results. Shouldn’t I be seeing something closer to 160 MB/s write and 175 MB/s read?
    FWIW: Quad-Core Intel Xeon Mac Pro 2.93 GHz, 16GM RAM
    Thoughts?
    Thanks.
    Glenn Camhi replied 15 years, 4 months ago 2 Members · 3 Replies
  • Bob Zelin
    May 3, 2011 at 12:43 pm
    you sure should be getting dramatically better results.
    You have a major problem with your G-Speed eS. Time to call
    G-Technology, or Highpoint, that makes your host controller card.
    Bob Zelin
  • Glenn Camhi
    May 3, 2011 at 4:40 pm
    Thank you, Bob. I’ll report on what I discover.
    BTW, in studying this issue I’ve read many of your posts from the past year or so, and found them quite helpful and clearly written. Thanks.
  • Glenn Camhi
    May 6, 2011 at 11:29 pm
    Solved. I wasn’t using the best controller card. Now I’m getting 158.4 MB/s write, and 177.1 MB/s read. Phew.
