Activity › Forums › Adobe After Effects Expressions › ‘Slot Machine’ effect to change numbers
  • ‘Slot Machine’ effect to change numbers
    Posted by Bas V breugel on May 1, 2019 at 9:18 am
    I’ve made it sofar that the position can change without keyframes. And was thinking to add a intertia bounce effect on the end.
    Then to somehow make the control layer (slider control) say if you type ‘3’ then go to ‘3160’.
    Or is there a more logic way? Because, what if the are 3 digits… The last number should go faster then the first. (If you go from 3999 to 4000).
    Filip Vandueren replied 7 years, 4 months ago 2 Members · 1 Reply
  • Filip Vandueren
    May 1, 2019 at 12:32 pm
    Hi there,
    you’ll find plenty of good tutorials and answers on this subjects if you search for “odometer”
    Good luck!
