Activity Forums DaVinci Resolve Slog3 – LUT – Right workflow?
  • Slog3 – LUT – Right workflow?
    Posted by Luke Sheldon on June 20, 2020 at 11:01 pm
    Hi all,
    I would be very grateful if I could get some feedback on the workflow I’m trying to use.
    DP shot in slog3. She used the ‘Phantom Arri Slog3’ LUT as a reference and I’m trying to use it in my grade. It’s Slog3 to Rec709.
    So I set the Project Settings to Davinci YRGB (not color managed) input = slog3. Looks great on export.
    1. When I change exposure on a node before the LUT the blacks won’t move below a certain baseline (about 50 on the waveform). However, if I add an exposure node after the LUT I can make those blacks real black (as opposed to a subtle ‘lifted shadows look’). It just feels like I’m doing something wrong somewhere.
    2. If I want to export the film for a digital projector for a film festival, I’m assuming it won’t be in rec709 so I’ll have to convert the output color space. And so by using a rec709 lut will I have to start from scratch to export for a p3 (or whatever) color space?
    Thanks so much. I tried researching this but didn’t get far.
    I’m on Mac Mojave 10.14.6
    iMac pro 5k retina
    Davinci Studio 16
    Luke Sheldon replied 6 years, 2 months ago 2 Members · 2 Replies
  • Michael Gissing
    June 22, 2020 at 7:37 am
    Typically I use three nodes when using a LUT. Node 1 is for pre LUT trimming. Node 2 is the LUT. Node three is the post LUT trim. Very normal to set final white & black levels after the LUT but often need the node pre LUT to avoid clipping or crushing (highlight, shadow recovery etc). I also sometime do a basic balance pre LUT then finesse post LUT. After that whatever else I need to tweak I add more nodes.
  • Luke Sheldon
    June 22, 2020 at 5:36 pm
    Thank you Michael! Good to know it’s not just a setting somewhere I should have checked.
