Activity Forums Apple Final Cut Pro Legacy Slo Mo Vibrations
  • Slo Mo Vibrations
    Posted by Lee Burrows on June 14, 2005 at 8:13 pm
    I have a slo-mo where the speed of the shot is 60%. Its a pretty static shot with a family walking in it as pretty much the only movement besides a slight pan of the camera. The whites on the gutter of the ouse and the greeb shrubs in the yard are vibrating heavily. Is there a filter that I can use to get rid of this and keep the slo mo?
    Lee
    G5 Mac OS X
    Dual 2.0 Ghz
    FCP 4.5 HD
    XServe Raid 1 Terabyte
    G4 Mac OS X
    Dual 1.25 Ghz
    FCP 4.5 HD
    Lacie Drives 200 Gbs
    Ivan George replied 21 years, 2 months ago 4 Members · 6 Replies
  • Gunner Jones
    June 14, 2005 at 8:40 pm
    Is that the way it looks on the video monitor? If not, check it there.
    O&O-Gunner Productions
    FCP-Avid-After Effects
  • Lee Burrows
    June 14, 2005 at 8:46 pm
    Thanks for the quick response, Gunner.
    Yeah, unfortunately it is the way it looks on my FCP monitor and video monitors. Would anti-aliasing or de-interlacing help?
    Lee
    G5 Mac OS X
    Dual 2.0 Ghz
    FCP 4.5 HD
    G4 Mac OS X
    Dual 1.25 Ghz
    FCP 4.5 HD
  • Gunner Jones
    June 14, 2005 at 8:55 pm
    Lee,
    You might try these suggestions for high quality rendering:
  • Joe Murray
    June 15, 2005 at 2:08 am
    Slomo with interpolation (i.e. frame blending checked) often produces this type of artifact on fine lines or areas with detail like the shrubs. FCP is creating blended frames between the existing ones by blurring a combination of the frame before and frame after, so the shimmering effect is the result of every other frame being blurred to smooth out the motion. It works well on motion but not on areas of static high detail. Twixtor (by ReVision FX) is a plugin that deals with this well, but you may be able to accomplish a better result by isolating the moving parts of the image with a moving mask (around the people), and place that layer over the static background played at 100% to avoid the artifacts. Twixtor does this by allowing you to define certain parts of a shot with masks and change the speed of each with different choices for interpolation.
    Hope this helps,
    Joe Murray
  • Lee Burrows
    June 15, 2005 at 3:49 pm
    Thanks Gunner
    G5 Mac OS X
    Dual 2.0 Ghz
    FCP 4.5 HD
    G4 Mac OS X
    Dual 1.25 Ghz
    FCP 4.5 HD
  • Ivan George
    July 1, 2005 at 4:22 am
    I’ve been editing DV for some time now. I’ve tried everything in fCP to get the cleanest slo mo possible. I found that setting slo mo to 40% is the cleanest ever.
