Activity Forums DSLR Video slo-mo (but not that slow)
  • slo-mo (but not that slow)
    Posted by Chris Larsen on February 14, 2012 at 2:51 am
    So I have done some tests with 60 fps conformed to 24fps conformed via cinema tools but that is too slow for me. I have done some speeding back up in final cut, but it either choppy or it regains the look of 60fps, which I do not desire.
    Here is an example of what I shot
    https://www.youtube.com/watch?v=plQRXoceZn8
    Canon 7d
    720p60
    1/125
    800 – 1000 iso
    18-55 efs lens (mostly 18mm with aperature around 4.5 or 5.6)
    I am only pleased with the 3rd shot (on the rainbow shaped rail) but that speed is too slow for every slo-mo shot. How do I get smooth looking slow mo that is nearer to .75 of original speed? Also do I need to adjust my shutter speed/angle to get the right blur? Please help!
    Chris Larsen
    the only really smooth clip is the 3rd (rainbow shaped rail), which kept it’s original timing
    Andrew Somers replied 14 years, 7 months ago 3 Members · 3 Replies
  • Chris Larsen
    February 14, 2012 at 7:16 am
    Just for clarification the 3rd clip is at 24fps
  • Steve Crow
    February 14, 2012 at 4:27 pm
    You might try the optical flow technology built into Apple Motion.
    Steve Crow
    Crow Digital Media
    http://www.CrowDigitalMedia.com
  • Andrew Somers
    February 15, 2012 at 5:23 am
    Assuming you want to be finishing at 24 fps, then shooting at 30 fps will “take the edge off” without being overly slow.
    Also, if shooting at 60, try using the longest shutter speed possible (should be close to 1/60), and then use “Twixtor” or “Kronos” (plug ins for after effects), or AE’s own time remap option (with flow field analysis).
    In any case, avoid using a shutter speed faster than 1/125 when shooting at 60fps, as motion will tend to be “stroby/stuttery”.
    A combination for flow and frame blend should give you some decent variable rates out of the 60 fps.
    Don’t waste your time trying to varispeed in Final Cut Blow, as that will only lead to frustration.
