Activity › Forums › Apple Final Cut Pro Legacy › slo mo 24p footage?
  • slo mo 24p footage?
    Posted by Craig Sawchuk on July 3, 2007 at 3:09 pm
    It’s great that there is a place you can go when you realize you’re clueless about something…
    I shot some 24 p footage in Ireland with Sony HVR V1U (recorded in HDV @ 29.97 using 3:2 pulldown). I want to slow a pan of Dublin shot from the Guinness Gravity Bar (might be the reason it’s a bit fuzzy)… Anyhow because of the pulldown I’m not getting a clean slomo image. Is there a way within FCP I can get rid of the pulldown? Will I have to recapture @24? Can I convert with compressor?
    Thanks for the assistance.
    Craig
    Del Holford replied 19 years, 2 months ago 2 Members · 1 Reply
  • Del Holford
    July 3, 2007 at 3:17 pm
    No matter what NLE you’re using, doing processing (FX) on footage always works best in the native resolution. Since you shot 29.97 it will work best to put the slo-mo on that footage and then do the pulldown again on the newly created clip.
    Del
    fire*, smoke*, photoshopCS2
    Charlotte Public Television
