Activity › Forums › Apple Final Cut Pro Legacy › Slipping sync by one feild
  • Slipping sync by one feild
    Posted by Nadia Diggins on November 8, 2007 at 11:43 pm
    I’m wondering if its possible to slip sync in FCP 4.5 by one field? My problem is that I’ve had some SD footage up-resed to 1080i, which has put the vision out of sync by one field only.
    Jeff Greenberg replied 18 years, 10 months ago 3 Members · 2 Replies
  • Aaron Neitz
    November 9, 2007 at 1:57 am
    You’ll have to eyeball it, just double click your mix tracks, hold down shift in the source window, and you can subframe edit your audio and set a new IN point.
    but honestly, by the time anything airs, 1 field here or there won’t make any difference in sync.
  • Jeff Greenberg
    November 9, 2007 at 12:55 pm
    I agree with Charlie here on both items…
    a) Subframe audio slipping
    b) most people don’t notice a problem until *3 frames* out of sync…
    With that being said, are you sure your monitoring FCP correctly? If you’re monitoring the footage @ the NTSC monitor…pipe your audio through there (and not through FCP on your computer.)
    Best,
    Jeff G
    Principal Instructor
    Future Media Concepts
    FMCTraining.com
    Editorsretreat.com
