Activity Forums Adobe After Effects Slipping a clip
  • Slipping a clip
    Posted by Guy on September 3, 2005 at 4:44 pm
    is there a way to slip a clip in the timeline. Not sliding, but slipping, where the in’s and out points change but the timing of the clip stays the same.
    thanks!
    Antony Buonomo replied 21 years ago 4 Members · 4 Replies
  • Ronn Trevino
    September 3, 2005 at 6:36 pm
    ok say your clip is trimmed on the timeline. There is excess grayed out footage on either end of you trimmed clip.. you drag that back and forth and that does your slipping.. correct? or is that called sliding?
  • Guy
    September 3, 2005 at 9:57 pm
    no, you are right. My Question was a little off, actually.
    I am not trying to slip a clip, the timing of the clip should stay the same, I want to slip the IN and OUT points at the same time. I wonder if there is a way to do this?
  • Steve Roberts
    September 3, 2005 at 10:27 pm
    I guess you want to do two roll edits simultaneously?
    Anyway, the answer is no. You can only drag one in/out point at a time, or set one at a time using the alt-[ or alt-] shortcuts. However, you can trim a bunch of selected layers to the same point by using one of the shortcuts … if that helps.
    Are you finding that AE is a very slow editor? 🙂
    Steve
  • Antony Buonomo
    September 4, 2005 at 7:03 pm
    Can’t you just open the layer in it’s own source window? Then you can edit the in/out points, roll/slip the selected portion to different i/o points… etc
    A
    Vertigo Productions
    https://www.vertigo.co.uk
