Activity › Forums › Apple Final Cut Pro › slip visuals and connected audio moving when I dont want it to
Posted by Ben Scott on August 24, 2011 at 5:22 pmI came across something annoying today
often the audio is where you might start an edit by telling the story but you always need to connect audio to the video track e.g. music may come in at a specific place and other audio may need to be in relation to that
when I come to slip the video clip later it moves the audio to somewhere else in the timeline when I want it to stay where it has been placed
only solution was to connect the audio to another video temporarily or move the video as a connected clip with a blank placer clip left on primary storyline
other solution is of course to create one massive blank placer clip and connect everything to this but seems to defeat the purpose
is there any other way to get this to work e.g. a secondary storyline for audio
realise a compound clip on the audio would achieve this but way too much of a fudge
Ben Scott replied 15 years, 1 month ago 6 Members · 7 Replies -
Tom Wolsky
August 24, 2011 at 6:55 pmYou can make audio a secondary storyline if you wish. Some users who are working with music are putting the music itself on the primary storyline and connecting everything to that so it’s free to move about.
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
Coming in 2011 “Complete Training for FCPX” from Class on Demand
“Final Cut Pro X for iMovie and Final Cut Express Users” from Focal Press -
Mark Morache
August 24, 2011 at 8:41 pmI’ve had to try to workaround this one as well.
Reconnecting the audio to another clip is quite easy actually, with a OPT-CMD-click.
If the clip is short and doesn’t extend over the end of the clip it’s connected to, that’s another problem.
I’ve noted the time displacement when I roll a clip, then move the connected clips correspondingly.
I’ve match-framed the clip I’m trying to roll, found my new inpoint on the event bin, and replaced the clip in the timeline with itself with the new inpoint. Before I do this I copy the effects on the clip, then paste them back in. Annoying, but effective.
Here’s another workaround I just tried, and it seems to work. Turn on your snapping (N), opt-click the clip you want to roll and drag it to make a copy of it, directly above itself. Roll that clip to get it where you like, then overwrite it back to the primary storyline. When I tried it, it replaced the clip in the primary storyline, and left the audio of the clip it replaced hanging below the storyline, which was easy to delete.
Clearly, they need to allow us to roll a clip without changing the connected media. I’ve sent a feedback, but I encourage people to send feedback and ask for this!
In trim mode, the option key takes you out of slip into slide. Holding down the command key makes the changes very fine. Perhaps Shift-dragging could roll the clip and keep the connected clips stationary.
I have faith that Apple will fix these things. I only pray that the programmers will be smart enough to figure out how to make them work with this damned magnetic timeline interface. I’m afraid that by the time we twist backwards, holding down three modifier keys with four fingers on our multitouch pad, it would have been a whole lot easier if we had a simple track-based timeline.
I’m calling it FCX. They took the “pro” out, so I will too.
I’ll reconsider after the first upgrade.Mark Morache
Avid/Xpri/FCP7/FCX
Evening Magazine,Seattle, WA
blogging at https://fcpx.wordpress.com -
Greg Gilpatrick
August 24, 2011 at 8:47 pmI second Tom said: Make the music track your primary storyline. I am working on a music video in FCPX at the moment and it sort of upset me at first that I couldn’t edit the “normal” way but after trying it out with the audio as the primary storyline for a little while, it actually made quite a bit of sense to do it that way. You’ll probably want to make your picture clips into a secondary storyline attached to the music so you can trim, transition, etc.
On Edit: I just realized Tom said something totally different. 😉
So, I suggest using your music as primary – perhaps in a compound clip.
Jeremy Garchow
August 24, 2011 at 10:32 pmThere’s a couple of workarounds that are pretty easy (but of course they should seem unnecessary), I agree a modifier key is needed here to slip the clip while keeping connected clips in place. Holding shift, or whatever seems like it would be a decent thing to add.
The “easiest” way right now to do this is to make your primary clip a compound clip (option-g), then open the clip in timeline (double click), do your edit, go back to the main timeline by hitting the back arrow in the top left corner of the timeline then break apart (command-shift-g). This keeps everything as it was, except the slip that you did.
The other way is to lift that clip out of the primary storyline with command-option-up arrow. Do your slip, then put back in primary with command-option-down. The only problem here is that if you had transitions in the primary, you will have to remake them as they get lost when you put the clip back down in the primary.
Jeremy
Robert Bracken
August 25, 2011 at 8:03 pmMIND BLOWN
I finally get magnetic timeline.
Put all your A-roll in the magnetic timeline. BOOM done.
Everything else is gravy. -
Jeremy Garchow
August 26, 2011 at 12:10 am[Robert Bracken] “Put all your A-roll in the magnetic timeline. BOOM done.
Everything else is gravy.”Sometimes the trick is figuring out what the “A-roll” is. It might not always be visuals.
Ben Scott
August 26, 2011 at 4:04 pmI tried the move the clip I want to visually slip to a connected clip with the gap clip left on primary storyline, this seems the most robust way, use alt cmd up or down to move off primary stoyline
the storyline way and reconnect whereabouts u attach to primary storyline using alt cmnd click works sometimes but not when overlapping audio (as you cant create the storyline) or when there isnt anywhere to sensibly reconnect
I agree for music based edits you should have the music as the A roll and connect the other clips to this
think my intial post was vague, I was actually refering to a piece of audio that continued from a previous shots dialogue but was the audio only from another take, standard thing when editing dialogue
