Activity Forums Apple Final Cut Pro Legacy Slip Tool problems
  • Slip Tool problems
    Posted by Robert Paige on November 1, 2011 at 11:47 pm
    I been having problems recently with the Slip Tool.
    For some reason when I use it on the clip, the first frame of that clip doesn’t match the left window of the 2 window display, when the slip tool is used. It shows a different time of the clip when changed and doesn’t match. I’ve never had this problem before but I believe it might be a setting or some sort of preference that has been changed.
    Jerry Hofmann replied 14 years, 10 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    November 2, 2011 at 2:08 pm
    You’re unclear here. Explain the problem a different way. There is no settings BTW that affect the slip or slide tools…
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
