Activity Forums DaVinci Resolve Slip & Slide without the annoying “4 up” view?
  • Slip & Slide without the annoying “4 up” view?
    Posted by Mel Matsuoka on February 26, 2016 at 2:39 am
    I’m trying to fix a Premiere Pro conform disaster in Resolve 12, and am a bit disappointed to find that I still haven’t been able to figure out how I can use the Slip/Slide keyboard shortcuts in the Edit Page to nudge an edit frame by frame, *without* the super annoying 4-up view always popping up.
    I’m using the Difference Mode trick to align an offline reference Quicktime with the imported XML, and just want to be able to slip/slide a clip with the keyboard until it’s perfectly aligned with the Diff-mode offline reference, located in the track directly above it. But the damn 4-up view makes it impossible to do that, because I can’t see the the composited Difference mode while I’m nudging the clip back and forth.
    Is there a trick to getting this to work in Resolve?
    Rohit Gupta replied 10 years, 6 months ago 2 Members · 1 Reply
  • Rohit Gupta
    February 26, 2016 at 7:50 am
    If you use the mouse, you can hold the Shift key to disable the 4-up preview.
    Currently, it’s not possible to disable the 4-up/2-up when using keyboard editing.
