Activity Forums Apple Final Cut Pro Legacy Slip or Slide tool in Multiclip?
  • Slip or Slide tool in Multiclip?
    Posted by Thomas on August 2, 2007 at 10:45 pm
    Is there anyway to use the slip or slide tool if your multiclips aren’t completely in sync?
    I know you can do this once the multiclip is in the timeline but what about just sliding the one clip in the viewer window to make the clip in sync after it’s been multiclipped?
    The sliding function seem to work in the viewer but it affects all the clips instead of the selected clip.
    Is this possible or Final Cut 6 doesn’t have this option yet?
    Rick Diamond replied 19 years, 1 month ago 3 Members · 6 Replies
  • Tom Wolsky
    August 2, 2007 at 10:55 pm
    In the Viewer hold Control-Shift and drag the clip. Is that not working for you?
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
  • Thomas
    August 3, 2007 at 1:42 pm
    Control-Shift is a function that slides all of the clips together within the multiclip.
    I’m trying to just slide one video within the multiclip.
    I’m assuming you can’t do this with Final cut 6
  • Tom Wolsky
    August 3, 2007 at 1:57 pm
    It’s broken. That’s why I asked if it worked for you. It seems to work weirdly, intermittently, not as it’s supposed to, and not as it did in the previous version.
    All the best,
    Tom
  • Thomas
    August 3, 2007 at 1:59 pm
    Do you mean ‘broken’ as it’s a bug?
  • Tom Wolsky
    August 3, 2007 at 2:14 pm
    That’s what it looks like.
    All the best,
    Tom
  • Rick Diamond
    August 3, 2007 at 11:40 pm
    It does seem to be a bug. It works in some timelines but not others. Don’t know why. It really was a problem in my last multi-clip job. The workaround, of course, is to sync perfectly in the bin.
    Rick
