Activity Forums VEGAS Pro Slip events by a number of frames
  • Slip events by a number of frames
    Posted by Ellen Maurer on October 3, 2015 at 11:11 am
    Hi!
    I need to slip multiple events. Is there a way to slip them using something that would allow me to enter a number of frames? Is hard to use those previews which are confusing and don’t really understand how to slip frame by frame and I need to count a lot of them.
    With thanks,
    Ellen
    Wayne Waag replied 10 years, 11 months ago 3 Members · 5 Replies
  • Aleksey Tarasov
    October 3, 2015 at 12:45 pm
    The best way – find (or write) a script which can do it.
    If this is a one-time task, you can use Vegasaur toolkit, free trial version (Quick Properties module > Events > Take Offset).
  • Ellen Maurer
    October 3, 2015 at 1:35 pm
    1. Don’t know if I’ll ever be able to just think of making a script 😀
    2. That worked! thank you very much!
    Ellen
  • Wayne Waag
    October 3, 2015 at 6:27 pm
    You probably know this already, but another way to easily slip events without a script is to first, select the events to be slipped. Then enter the num-1 key to move one frame left or num-3 to move one frame right.
    wwaag
  • Aleksey Tarasov
    October 3, 2015 at 6:37 pm
    This is called “sliding” while “slipping” is shifting the contents of an event w/o moving the event.
  • Wayne Waag
    October 3, 2015 at 8:19 pm
    [Aleksey]
    Thanks for pointing that out. It seems that I learn something new here almost every day. So, slipping would be akin to using Vegasaur and taking a specific offset under Events in its Quick Properties, which I do quite frequently. Just didn’t know I was technically “slipping”.
    wwaag
