Activity › Forums › Adobe Premiere Pro › Slip edit subclips…
Slip edit subclips…
Posted by Richard Herd on February 19, 2014 at 9:01 pmI cannot seem to get subclips to perform slip edits. (CS6).
Richard Herd replied 12 years, 7 months ago 3 Members · 7 Replies -
Paul Neumann
February 19, 2014 at 9:25 pmRight click on the subclip in the Project bin. Select Edit Subclip. Uncheck the Restrict Trims To Subclip Boundaries.
Alex Udell
February 19, 2014 at 9:28 pmif you drop the entire subclip into a sequence, the sequence is treating it like a whole clip and respecting the artificial limits you placed on it when you created the sub clip.
you can tell this when you load the subclip in the source viewer.
however, with the clip selected if you choose “edit subclip” from the clip menu….
you can turn off the “restrict trims to subclip boundaries”
this should allow you to do what you need.
thanks!
Alex Udell
Editing, Motion Graphics, and Visual FX -
Paul Neumann
February 19, 2014 at 9:34 pmThat might be CS6 behavior. It’s not like that in CC. Sorry for the confusion. In CC when you make a subclip the naming dialogue box even has the Restrict option right under the name field.
Richard Herd
February 19, 2014 at 9:39 pmBummer.
Another frustration.
I have clip that has 5 different projects in it; it’s a dolly shot in a show room. The agreement between the retailer and the wholesaler means he needs to have BRAND1 separated from BRAND2 and so on. So I made metadata fields and set in and outs for the particular brands. HOwever! the metadata field populates every clip at once, although I have tried two ways, just clips, and subclips.
Do I need to do this in Prelude? (I guess that’s what I’ll try now.)
Paul Neumann
February 19, 2014 at 9:45 pmThat would be my suggestion. What’s kinda cool is that you can ingest that clip and mark it with 5 different subclips and then just save the project. When you import that one clip into PPro you’ll get it and the 5 subclips come along for the ride.
Richard Herd
February 19, 2014 at 10:14 pmThe chain icon was engaged, now they are no longer linked! So all is good, happy editor.
