Activity › Forums › DaVinci Resolve › Slip dynamics channels
Posted by Adam Berk on September 28, 2011 at 2:22 amAnyone know if it’s possible to slip an entire dynamics channel, or are we limited to sliding marks individually? I just had to redo a complex window animation when all I needed to do was slide the whole animation by few frames. I know I must be missing something.
Vivek Vedagiri replied 14 years, 12 months ago 3 Members · 4 Replies -
Sascha Haber
September 28, 2011 at 7:45 amGood idea !
Like an overlaying block on the timeline, like a transition box, that holds the whole animation would be awesome.A slice of color…
DaVinci 8.0.1 OSX 10.7
MacPro 5.1 2×2,4 24GB
RAID0 8TB eSata 6TB
GTX 470 / GT 120
Extreme 3D+ WAVE -
Adam Berk
September 28, 2011 at 7:50 amI come from smoke/flame, and there I’m used to a switch that lets one view and edit animation channels either as keyframe data (keyframes with curves between them) or tracks (with which you can slip, compress or expand entire animation channels). I’m not sure, but I would assume that it works the same or very similar in Lustre as well.
Another simple option would simply be to allow us to multi-select the marks! I can’t believe that I can only select one mark at a time (shift and command do nothing).
Adam Berk
September 28, 2011 at 7:56 amIf anyone’s wondering why I needed to do such a thing….
I was manually color tracing from another timeline and the animation came in a bit off. Four frames off to be exact. This sync error was caused by the fact that I was using pre-conforms based on EDL’s that came out of the scene detect module (no source timecodes), and the shot I was tracing to didn’t have exactly the same frames or length as the shot I was tracing from. Seems like something that could be a fairly common scenario in rush grading pickup shots, no? It certainly can be for me.
Vivek Vedagiri
September 28, 2011 at 10:11 amHi Adam,
You can multi-select marks by holding down shift and drawing a lasso around the marks you want to select.
While holding the shift key down, if you click and drag the mouse, all the selected marks should move together.
Hope this helps.
Vivek Vedagiri
Blackmagic Design
