Activity › Forums › Apple Final Cut Pro Legacy › Slip audio without moving keyframes
Posted by Jason Fisher on February 24, 2011 at 3:23 pmIs it possible to slip an audio track whilst leaving keyframe edits to levels etc in the same position?
Andy Mees replied 15 years, 6 months ago 3 Members · 3 Replies -
Jerry Hofmann
February 25, 2011 at 1:38 amI’m afraid not, but you could copy the clip, slip it, then paste attributes from the copy, and do what you want.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Jason Fisher
February 25, 2011 at 10:11 amThanks Jerry – I did just discover I can slip the attributes within the audio window, so that works too.
Andy Mees
February 25, 2011 at 10:39 amyou can slip the attributes in the Viewer using the method explained here:
https://www.larryjordan.biz/articles/lj_audio_slip.htmlits a little imprecise in practice, but its a workable solution if needed
