Activity Forums Adobe Premiere Pro Slighty distorted audio when importing into Premiere?
  • Slighty distorted audio when importing into Premiere?
    Posted by Daniel Haskett on May 30, 2005 at 3:29 am
    Hi there
    Basically Ive saved some audio as a wav file in After Effects and imported it into Premiere, I saved it as a 44.1khz 16bit stereo file but for some reason in premiere there is slight distortion when it gets louder in places…any ideas why and whether this is only in the preview or will actually render like this?
    Dan
    Dan Plonsker replied 21 years, 3 months ago 3 Members · 2 Replies
  • Steven L. gotz
    May 30, 2005 at 4:40 am
    Keep the audio to no higher than zero (use the master volume meters in the audio mixer). Average of about -6dB should do the trick.
    Steven
    Adobe Premiere Pro 1.5 / After Effects 6.5 Pro https://www.stevengotz.com
    Learning Adobe Premiere Pro 1.5 https://www.lynda.com
    Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5
  • Dan Plonsker
    May 30, 2005 at 9:06 am
    Your project may be configured to Audio at 48Khz. convert the sound and it should be ok.
