Activity Forums Adobe After Effects SlightOT: Vector Shapes from PS to AE
  • SlightOT: Vector Shapes from PS to AE
    Posted by Stuart Fellows on August 27, 2007 at 3:46 pm
    Since I have no skills in Illustrator, I’m testing various shapes layers in Photoshop and importing to After Effects. I’ve notice two things that I don’t entirely get. Just to preface these are actual shapes, no masks (which I know is a copy and paste operation)
    Anyway, first, it seems to import as layers in AE the PS layers must be rasterized ? Leaving them as vector shapes and importing leaves me with nothing but the color (if there is one) of the shape layer. BTW, yes I know I can create shape layers direct.
    So once I found I needed to rasterize (and this was basically on my own doing), once inside AE I wanted to turn the constant rasterize box in the layers (panel ? :)) Seems though that is disable for these imported layers. I guess that is because they are no longer vectors.
    So now that I’ve probably confused everyone, is there a way to get a vector shape into AE from Photoshop ? And if so what would be the steps. I mean I know I can do them from Illustrator, so are the vectors’ different in PS from Illustrator ?
    TIA
    Stuart
    Stuart Fellows replied 19 years ago 57,625 Members · 3 Replies
  • Stuart Fellows
    August 27, 2007 at 4:00 pm
    Cool Dave, Thank you for that heads up. I might have bypassed it based on the name.
    Stuart
  • Stuart Fellows
    August 27, 2007 at 5:33 pm
    I did watch the video and actually remembered I’ve watched it before however, my original post was probably confusing. I do not have a problem with Vector Masks, the problem is with Vector shapes, out of Photoshop into AE. They show up fine as a comp, but the layers contain no vector shape ? Hopefully I’m explaining myself better.
    TIA
    Stuart
  • Stuart Fellows
    August 27, 2007 at 10:06 pm
    Yep, it seemed that was the case but wanted to check.
    Stuart
