Activity Forums Adobe Premiere Pro Slightly OT: Professional looking labelling
  • Slightly OT: Professional looking labelling
    Posted by William Mcqueen on July 16, 2005 at 12:42 pm
    So you’ve just finished your “Gone with the Wind” or a DeMille extravagaza and you’ve mastered it to DVD. It’s an amazing piece of editing and it’s time to provide a preview copy for the client.
    What experience with specific products (that don’t cost a small fortune) has people had with stand-alone labelling equipment for the one-off diskette for “the client.”
    Which equipment works, are reliable and aren’t going to die after 10 copies. Also, the ink supplies seem to be very expensive, even if the machine isn’t.
    Suggestions, collective wisdom or other discussion locations appreciated as always.
    Bill in Toronto
    George Socka replied 21 years, 1 month ago 5 Members · 6 Replies
  • David J
    July 16, 2005 at 4:45 pm
    I use a Canon i965 inkjet which can print directly onto printable CDs and DVDs. There are cheaper alternatives with the same facility.
    Results in my case are excellent and the Canon label-print software makes design a brezze.
  • George Socka
    July 16, 2005 at 6:20 pm
    Epson photo 200 – 300 etc. It is inkjet ink but DVD’s are not that large. Their Print CD program is nice enough. Otherwise create the image in photoshop.
    Question about the Canon – is the ink waterproof? If you rub it with a wet finger does it smudge? The Epsons do smudge.
  • Mike Velte
    July 16, 2005 at 6:53 pm
    The best labeling software I have found is Discus Labeler.
    https://www.magicmouse.com
    I have tried dozens and this is slicker than snot…
    It has layouts for most printers and labels, including the R200 and Premira Bravo which is a very slick automatic printer that does one offs just fine.
  • Bart Conover
    July 16, 2005 at 11:07 pm
    I agree with Mike . . . I use Discus as well and it’s great!
  • David J
    July 17, 2005 at 8:23 am
    I have had no problems with smudging of labels from the Canon, and I use mostly compatible inks rather than the expensive Canon originals. Neither have there been any complaints from customers about any of the hundreds of CDs and DVDs I have produced with this printer
    However, I’ve just tried rubbing a sample quite roughly with a wet finger, and I did generate a smudge. There are products available to cover the label with a waterproof layer after printing if this is an issue.
  • George Socka
    July 17, 2005 at 3:36 pm
    The Epsons smudge, but again nobody has compained. Just hoping that maybe there was a better low cost solution.
