Activity › Forums › Apple Final Cut Pro Legacy › Slightly OT: Networking Issue
  • Jeremy Garchow
    June 22, 2009 at 3:04 pm
    [David Roth Weiss] “You may be correct, but I want to be sure before mentioning it to my friend who assured me he knew how to do the wiring. “
    A ha! Did your friend actually do the crimping of the RJ-45s?
  • Eric Jurgenson
    June 22, 2009 at 3:47 pm
    David,
    Cat5 cable has 8 conductors, 4 of which are actually used for an Ethernet connection – 2 transmit, and two receive. If you don’t use the right color order on the pins, but are consistant with the connectors on either end, the cable will work – there is an electrical connection from the correct pin to the correct pin, but since Ethernet uses a balanced pair for both transmit and receive, it is important that the balanced signal is sent down the same twisted pair in order to cancel out common mode interferance. If you use the wrong color order, you might have one leg going down one twisted pair, and the other leg going down another. If you happen to have T and R signals going down the same twisted pair, there is further potential for crosstalk, which is made worse with higher frequencies (GigE) and longer lengths.
    The correct color order is readily available online – Google it (or maybe Bing it ;>)
  • Arnie Schlissel
    June 23, 2009 at 2:00 am
    [David Roth Weiss] “my friend who assured me he knew how to do the wiring.”
    That loud sound you just heard was the sound of me rolling on the floor laughing.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • David Roth weiss
    June 23, 2009 at 5:36 am
    [Arnie Schlissel] “That loud sound you just heard was the sound of me rolling on the floor laughing. “
    I have along memory Arnold…
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Arnie Schlissel
    June 24, 2009 at 12:34 am
    [David Roth Weiss] “I have along memory Arnold…”
    but i’m laughing with you! (And at your friend)
    Arnie
  • David Roth weiss
    June 24, 2009 at 12:57 am
    [Arnie Schlissel] “but i’m laughing with you! (And at your friend) “
    I forgot, what were we talking about?
    BTW, my cable making days are over. I’m going to buy pre-made, pre-tested cables from now on. Life is too short…
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Arnie Schlissel
    June 24, 2009 at 3:12 am
    [David Roth Weiss] “I forgot, what were we talking about?”
    I believe we were talking about what a good dog Auggie is!
    Arnie
Page 2 of 2
