Activity Forums Apple Final Cut Pro Legacy Slightly OT but perhaps not
  • Slightly OT but perhaps not
    Posted by Blub06 on September 16, 2006 at 10:38 pm
    Sometimes I work with Avid systems that are hooked up to the usual Unity server but connected through a gigabit Ethernet router. Is it at all possible for hard driver companies to make their hard drives usable through the Ethernet port, perhaps connecting to a router bridge then on to the Mac?
    If it is possible, I wonder why they are not available and if they are available where I might get one and if I can get one why doesn
    Mark Maness replied 20 years ago 6 Members · 7 Replies
  • 7 Replies
  • Shane Ross
    September 16, 2006 at 11:02 pm
    They are…it is called Fibrechannel and SAN. XSan, SANmp and metaSAN are FCPs answer to Unity. And no, it isn’t inexpensive. But, all these solutions are far cheaper than Avid’s Unity
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • David Roth weiss
    September 16, 2006 at 11:25 pm
    Chris,
    There are Ethernet drives available right now from all the major drive manufacturers, who call them “Network Drives.” However, they have several limitations.
    1. They are are too slow for video in most instances.
    2. They come formated FAT32, which wil work with MACs, but with a 2gb file limitation.
    3. You can reformat them with Linux to go beyond the 2gb limit, but its still not a perfect solution.
    DRW
  • Keith Koby
    September 17, 2006 at 12:27 am
    Check out Isolon. I’ve been told that is works and you can edit DVCPRO HD easily, although it isn’t a FCP “approved” storage device. It is expensive. We’re considering it for next year as a back up in case Xsan goes down. Also using it to back up graphic elements and as a place to move files when upgrading old san volumes to increase lun size above 2 TB.
  • David Roth weiss
    September 17, 2006 at 12:41 am
    Actualy its Isilon not Isolon.
  • Keith Koby
    September 18, 2006 at 2:09 pm
    Thanks. I think I was half asleep when I wrote that reply.
  • Joe Paolo
    September 18, 2006 at 2:32 pm
    A company called EditShare has ethernet storage devices that look very interesting.
    joe
  • Mark Maness
    September 18, 2006 at 8:56 pm
    For Mac and FCP, there is one major competitor to the XSAN. It called the TerraBlock by Facilis Technology.
    https://www.facilis2.com/
    It is absolutely AWESOME! I had a salesman introduce it to me just before NAB. So I took a good look at it while at NAB. I watched footage that was shot and edit 2k and it was flawless! It can be used to hookup any computer using any software and they can share it flawlessly. You can have you FCP stations hooked up with Avids and PCs running Premiere or Vegas sharing files all at the same time!
    It impressed us so very much that we are converting over to it next week!
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
